2006 King Ranch F-350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-05-2014, 12:38 PM Thread Starter
Semperfidoordie's Avatar
After much debate and quite a helpful thread on here I finally pulled the trigger a few weeks ago on a 2006 F-350 King Ranch 4x4. The truck is pretty clean and bone stock. So far I have done some reading on 6.0's and think I have an okay handle on what is necessary to keep them healthy.
I got a ScanGauge II and have been watching my EOT/ECT deltas on my way to work every morning and evening, 28 miles each way 80% highway at 60mph and they are 7-8* apart. Although the deltas are good and the truck shows no signs that cause concern when I open it up to do the coolant filter, EGR delete and studs should I swap the coolant and oil cooler as well?
Also regarding that when you swap coolant I assume some of the debris/gunk from the EGR is left built up in the coolant system and could potentially block the new oil cooler, how do you avoid that?
My long term plan is to eventually put a good suspension system on, like Carli or some equivalent and mostly just drive the heck out of it. I won't be building a race truck or anything insane just want a truck to pull a fifth wheel (a few years off right now) and go hunting/camping/fishing and family road trips. The high end suspension will be nice to handle family adventures and stay comfy on my long drive to and from the mine and interior upgrades for creature comforts to keep my son occupied on long trips.
I will make slow progress on the truck in the near term but plan on building it piece by piece as I have the money.
USMC/OIF Veteran
2005-2014
Semperfidoordie is offline
post #2 of 13 (permalink) Old 06-05-2014, 06:48 PM
"Slap hands slap hands"
FlossyB's Avatar
Re: 2006 King Ranch F-350
I would replace the oil cooler absolutely while you are in there so you don't have to potentially do it later. I would flush flush and flush again before replacing the coolant and adding in the coolant filter kit. congrats on the new truck enjoy!
JB
FlossyB is offline
post #3 of 13 (permalink) Old 06-05-2014, 11:01 PM Thread Starter
Thanks! I will have to be sure I replace it then.
USMC/OIF Veteran
2005-2014
post #4 of 13 (permalink) Old 06-06-2014, 01:13 AM
SledDogg's Avatar
Read threads on flushing. Flush BEFORE INSTALLING A NEW oil cooler. Install coolant filter then also. Drive for a bit. Many new oil coolers have been plugged quickly otherwise.
Do your hpop stc fitting, dummy plugs, & stand pipes.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #5 of 13 (permalink) Old 06-06-2014, 03:49 PM Thread Starter
Alright, thank you.
USMC/OIF Veteran
2005-2014
post #6 of 13 (permalink) Old 06-14-2014, 05:36 AM Thread Starter
To add to this...If I wanted to upgrade my truck in segments could I start with coolant swap/flush and coolant filter to start? Then move onto the rest once I have the time and what is the latest and greatest flush procedure? I think I read somewhere that Restore Plus is no longer the preferred thing to use.
USMC/OIF Veteran
2005-2014
post #7 of 13 (permalink) Old 06-14-2014, 07:42 AM
caissiel's Avatar
I would do a light flush with Dawn and fill with EC coolant.
That truck is in great condition.
Sent from AutoGuide.com App
2005, 6.0L, 6 Spd Std, F250SD. Extended Cab, 4 x 4 Long Bed, 2 Extra spring plies, Hypertech Max. Energy. 2008 ext. mirrors. Din2 Radio, GPS, Video, TV, SD & USB and Roof Monitor. Fuel Mileage 21MPG. EGR Cooler Deleted. Towing 15.5K lbs 5thWheel RV is 12MPG. ScanGaugeII Rocks.
caissiel is offline
post #8 of 13 (permalink) Old 06-14-2014, 01:35 PM Thread Starter
Okay. That is the thought process I had to. What is the capacity of our cooling system? I work for CAT so our ELC is readily available to me so that is what I will likely use. Thanks
USMC/OIF Veteran
2005-2014
post #9 of 13 (permalink) Old 06-21-2014, 08:41 PM
Those deltas sound good. Do you know what type of coolant it has in it now. I would check the high pressure side as Sleddogg suggested, do the upgraded oil cooler and do the blue spring mod if that applies to the 06 while you have it opened. Low fuel pressure can damage injectors and they cost $$$ (ask me how I know). Also don't forget to test the FICM voltages and the batteries condition. They say weak batteries contribute to FICM failures which can cause drivability problems.
03 Excursion Ltd 4x4, ARP studs/HG, EGR deleted, K&N CAI, turbo back exhaust, 6.4L banjo bolts, blue spring, coolant filter, IDP tunes, SCT Livewire
07 F250 King Ranch 6.0L SB (for sale)
96 Regal 258 Commodore
08 Jayco 31 BHDS G2
rowekmr is offline
post #10 of 13 (permalink) Old 06-29-2014, 02:21 AM Thread Starter
Thanks. My FICM feeds a constant 47.5-48v to my injectors. Unsure of coolant type...I know the degas bottle says -60 so hopefully it's good enough for a winter here. Picked up a SCT and Gearhead tunes so I will update once I get everything
USMC/OIF Veteran
2005-2014
