Air Bag question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-30-2014, 10:19 AM Thread Starter
Meandog06
meandog06's Avatar
Air Bag question
I have a 2004 F350 4x4 with a 6 inch lift and 37's. I've replaced the front left leaf spring 3 times, all 3 times changed the ride height but I just cannot get it equaled to the right side. Is it possible to install airbags/helper bags up front that I can run separate air supply to so I can level the front end side to side? I am pulling my hair out with this one.......wait, im already bald!!!!!
meandog06 is offline
post #2 of 10 (permalink) Old 05-30-2014, 12:34 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: Air Bag question
It's a common issue for these trucks. Do you have the proper lift parts installed? Drop trac bar bracket or adjustable trac bar? How much difference side to side?
Money can fabricate anything you want...just got to get to it.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #3 of 10 (permalink) Old 05-30-2014, 06:56 PM Thread Starter
Meandog06
meandog06's Avatar
All correct lift parts installed. Just cant seem to get 2 leaf springs sprung the same.
post #4 of 10 (permalink) Old 05-30-2014, 08:39 PM
Administrator
Zmann's Avatar
it's not unheard of to shim one leaf pack
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 10 (permalink) Old 05-31-2014, 12:26 PM
PursuitInterceptor
How much is the difference between the sides?
You dig.
post #6 of 10 (permalink) Old 06-03-2014, 11:53 AM Thread Starter
Meandog06
meandog06's Avatar
Just under an inch.
post #7 of 10 (permalink) Old 06-03-2014, 01:49 PM
Administrator
Zmann's Avatar
rear is level? and a bent frame has been ruled out ?
it's a pain but did you swap front springs side to side to see if the sag is indeed the spring ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 10 (permalink) Old 06-04-2014, 12:25 PM Thread Starter
Meandog06
meandog06's Avatar
No, but I did replace the sagging leaf spring a couple times. Does anyone sell shims to get that one side up?
post #9 of 10 (permalink) Old 06-04-2014, 01:56 PM
Administrator
Zmann's Avatar
it is a block of steel with a hole and a new center pin
you can make your own
also if you are not measuring to a frame point but are using the sheet metal as a reference point that may add to the problem
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 10 (permalink) Old 06-04-2014, 01:58 PM
Administrator
Zmann's Avatar
u can use these
Add a Leafs, Zero Rate for 4x4 Suspensions from Offroad Design
DTR's Donation page
RIP DTR Ron
Zmann is offline
