Getting P0261 and P0683 code at the same time. Also reading all other injector codes as well. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-26-2014, 12:08 AM Thread Starter
On my way home from work the other day my truck suddenly shut off. The truck has not been able to start since. Right before it shut off the truck would hesitate when I stepped on the accelerator and then it would eventually go. It didn't run bad, a little white smoke in the morning after I started it up but after it warmed up no problems. I recently bought an actron OBD 2 code reader and it read 11 different codes all having to do with either the FICM (injector codes for all cylinders) and the GPCM or glow plugs. Nine of the codes were pending but the two confirmed codes were P0261 and P0683 (which I understand as having to do with the FICM and the GPCM). I also just replaced the FICM because I thought that was the issue but the truck still will not start. Do these codes typically go together or is there some other underlying issue?
lukekg515 is offline
post #2 of 10 (permalink) Old 05-26-2014, 02:48 PM Thread Starter
Re: Getting P0261 and P0683 code at the same time. Also reading all other injector codes as well.
I should add that both batteries are good and holding at about 12.5v. When I tested the FICM it kept bouncing back and forth between 24 and 30 volts. That led me to think that the FICM was the problem. Also there is no white smoke that comes out of the exhaust when I try to start it for an extended period of time.
post #3 of 10 (permalink) Old 05-26-2014, 08:31 PM
"Slap hands slap hands"
FlossyB's Avatar
I am sure some of the more veteran guys will chime in but I agree with you sounds like a bad FICM here. I would replace with a upgraded one 58V that my next upgrade I am looking to do and sounds like its needed to get you back up and running again. I have never read or heard of all the injectors going out at once, only other thing I can thing of would be a lack of fuel issue throwing those codes for all injectors.
JB
FlossyB is offline
post #4 of 10 (permalink) Old 05-27-2014, 01:53 PM Thread Starter
Yea that really seemed like the problem so I'm not sure if I installed it incorrectly or not. I didn't purchase the ficm completely just the motherboard.
post #5 of 10 (permalink) Old 05-27-2014, 05:26 PM Thread Starter
So I assume the reason it's not starting is because the FICM needs to be reprogrammed since it was a new FICM. Just to make sure the FICM actually was the problem I tested the new FICM today and it read a constant 48v whereas the old one read, like I said previously, between 24 and 30v. Anyone know where to reprogram these things without going to a Ford Dealer or does it have to be done at a Ford dealer? My problem is that the truck can't start even with the old FICM so I'd rather not have to tow the truck just to reprogram the FICM. Thanks.
post #6 of 10 (permalink) Old 05-27-2014, 06:52 PM
FlossyB's Avatar
I only know of the speakership being able to do it. Call around to some local shops and ask they would know and hopefully be able to help.
JB
FlossyB is offline
post #7 of 10 (permalink) Old 05-27-2014, 11:33 PM Thread Starter
Definitely not spending another 160 to have the thing reprogrammed so I'm sending my old unit to FICMrepair.com to avoid the hassle of towing and dealing with a Ford mechanic. Hopefully having the old one fixed works out.
post #8 of 10 (permalink) Old 06-05-2014, 05:28 PM Thread Starter
Got the refurbished FICM and still won't start. I was wondering if it could be the alternator. I changed the belt recently because the power steering was going out. After I changed the belt it got a little better but still ran into some problems. No flickering of lights or anything happened so I'm wondering if the alternator went bad. Does that sound right?
post #9 of 10 (permalink) Old 06-09-2014, 11:55 PM
cjetcat's Avatar
Try your FICM relay.
I replaced both batteries and put my "spare" FICM module on my 2004.
It had all kinds of codes but it was just the relay.
New relay and all of the codes went away and it was up and running again.
Fairly cheap, worth a try......
F350 Harley Davidson 4x4 Crew Cab Short Box. ARP Studs, Hog Performance 4" 304 Stainless Exhaust, Mishimoto Intercooler and Radiator, Coolant Filter, Extreme X & Mild FICM Tune. Edge CTS w/ EGT and Fuel Pressure. 2011 Rear Bumper Powder Coated Competition Orange, Bed Rug, Truxedo Tonneau Cover.
cjetcat is offline
post #10 of 10 (permalink) Old 06-10-2014, 10:00 PM Thread Starter
Messed around with the ipr valve today and found out it was stuck and had no screen on it. Cleaned it out and reinstalled it and she runs like new. Working on getting a seal kit for it so it doesn't stick again.
