MTW MadMax Puller Edition - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-20-2014, 06:44 AM Thread Starter
6.0 Guru
Hello all, just thought I would update on my latest build. 2 years ago I pulled my engine out and tore it down to a short block and then built it back up with all updated Ford parts, OEM headgaskets, APR's, 155/30's, MTW Durastroke, R/R fuel system, 4" MBRP exhaust. Last year I added a Airdog 150. I sled pulled a couple times last year and never thought I would do good, just figured I'd try it. I had traction bars and suspension stops and I ended up with a couple 3rd and a 4th place finish against about 20 trucks. Top 2 are Duramaxs that are trailered in. My buddy says they are 550-600 HP trucks. I called Adrian and talked about my goals. He told me that he could build me a MadMax that would pass work stock rules and a 2.55 in plug would not fit in. We spoke a few more times before I made my final decision. I sent it in and had it back in 3 weeks. I needed it by the weekend and Adrian promised it would be here by Friday. He called me at 11:30 on Thursday night asking fory address and it arrived at my house Friday at 12:45pm. Wow, he really went out of his way to make sure it made it too me. The turbo looks great. I told him to just leave the cover plain and reuse the stock bolts. I didn't want anything shiny or new bolts because I don't want to attract any attention. Adrian called me twice on Saturday to see how things were going. Once I got everything done, I fired it up. Man this thing whistles like a son of a b##ch. It sounds like a jet. Idling it sounds like an absolute beast. Took her out for a spin and was running my IDP extreme street for my original stage 1. It spools just as fast as the original, but there is a huge difference mid and top end power. I then loaded my Wildman tow tune and pulled my 10k boat home from storage and it pulled like a champ. EGT's never got over 1300 degrees. Then I loaded my SPD and holy sh$t, it hauls azz! I haven't done any WOT 0-100 runs yet because I'm worried about my transmission. I put a PI Stallion converter in when I had the engine out, bit still leery. I am going to take it to Andy Warren and get the trans done. I was going to get my injectors turned into 190/30, but the lack of time and money put that on hold until next year. I took my best friend for a ride who is a Duramax guru. He has 5 duramax from stock to a 950 HP dually to a 1800 HP puller. He was very impressed and said he wouldn't be surprised if it mid to upper 500's HP. I can't wait to get some new tunes made for the turbo. I'm going to give Drew from BackRoad Performance. I hear he has tuned a few MadMax turbos.
I also put a Full Race ported intake from WPE. The intake is awesome also. It looks good, it wasn't warped at all, and the welds were perfect. I also got it unfinished again to draw no attention to my engine bay. It was between an APEX intake and WPE, but the wait was too long for the APEX and I wanted to show that I'm not biased one way or the other.
I am fully satisfied with my new turbo. It has been the best upgrade yet and I can't wait for after my transmission gets built and new tunes written, to see the full potential. My first pull I'm going to is on June 21st. I hope I can gain some ground against these Duramaxs. I will update this thread as needed. I want to thank Adrian for taking his time to talk to me and build me an awesome turbo and for getting it shipped overnight. And of I decide to go bigger in the future, I will look at getting another one of his turbos. Maybe his "Monster" or whatever he come up with next!
I'll post some pictures when you get home.
DieselDan73 is offline
post #2 of 7 (permalink) Old 05-20-2014, 04:31 PM Thread Starter
6.0 Guru
Re: MTW MadMax Puller Edition
Here is a picture of my motor torn down
Here are a couple of the turbo.
Here are a couple of the Full Race Ported WPE intake manifold
Here is a picture of my CTS going 70 mph up a slight grade.
post #3 of 7 (permalink) Old 05-31-2014, 03:37 PM Thread Starter
6.0 Guru
Wow, this forum is beyond boring.
2005 F-350 CCSB King Ranch
Fully Bulletproofed
MTW MadMax
Warren 155/30
R/R with Airdog 150 feeding stock pump
S&B intake
PI Stallion Coverter
FLO-PRO 5" Turbo back Straight piped
post #4 of 7 (permalink) Old 05-31-2014, 11:45 PM
Stroke it B!tch
fordboy11's Avatar
when are you gonna pull it next?
78 F-150 300 straight 6, 3 on the tree
03 F-250 6.0 Play toy
06 F-250 6.0 (general nightmare) 2.5 pulling truck
12 F-350 6.7 Tow rig
Gotta pay to play son!
Originally Posted by F-250-Owner View Post
I know you said you wouldnt turn it up..... but come on.... its like saying "I promise I will only stick the tip in" never happens like that
fordboy11 is offline
post #5 of 7 (permalink) Old 06-03-2014, 12:58 AM
nrook's Avatar
when i spoke to Adrian he told me about you. basically your turbo is the same as the Mad Max if i remember right, what kinda boost and egts you running with that setup I'm going to be sending mine to him for the mad max upgrade
nrook is offline
post #6 of 7 (permalink) Old 06-03-2014, 01:10 AM Thread Starter
6.0 Guru
I'm planning on pulling at Burton on the 21st. Just need to add my dual shocks up front and finish up my converter unlock switch and I should be ready. Still up in the air about pulling with my 35's or 33's. I got stock gears so I don't know yet.
Fully Bulletproofed
MTW MadMax
Warren 155/30
S&B intake
post #7 of 7 (permalink) Old 06-03-2014, 01:14 AM Thread Starter
6.0 Guru
Haven't got accurate boost numbers yet as I don't have my mechanical boost gauge hooked up yet. Just going off the CTS, but the map sensor maxes out. EGT's are good. Haven't stood on it yet hard on my race tune, but on my tow tune towing my 10k lb boat, max I was seeing was 1250. Cruising at 70 they are about 750-850 depending on grade. I'm very happy so far.
Fully Bulletproofed
MTW MadMax
Warren 155/30
S&B intake
