Where is the best place to install the Pyrometer? Also... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-09-2014, 07:12 AM Thread Starter
Hi guys,
Is there an ideal place to install the pyrometer? I got bd exhaust manifolds and there is a pre drilled hole for the pyrometer but I notice that some have the pyrometer install on the down pipe? Is one location better than others?
Do some member run multiple pyrometers?
And I was wondering where I can buy the fuel pressure sensor kit made by edge; I have a hard time finding one.
Thank you
HankyD is offline
post #2 of 8 (permalink) Old 05-09-2014, 11:53 AM
Swamp trash...
Merc82's Avatar
Re: Where is the best place to install the Pyrometer? Also...
Use the holes in the BD manifolds. I don't personally but there are some people who run dual pyros. Check Amazon or eBay for the Edge stuff.
Chris. 06 LBCC XL 44
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #3 of 8 (permalink) Old 05-09-2014, 06:10 PM
I run 3 pyrometers. 1 in the right manifold,1 in the left manifold and 1 after the turbo.
lenzhotrod is offline
post #4 of 8 (permalink) Old 05-09-2014, 07:55 PM
Good ol boy
04 f350's Avatar
I can't say I've heard of anybody running three lol what kinda temp split are ou seeing out of all three? I've always wondered if both manifolds gave off the same temp
Studded and Deleted
5 inch axle dump
Back Road Performance Tuned
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #5 of 8 (permalink) Old 05-10-2014, 12:38 AM
Both manifolds are very close in temp. After the turbo I see around 150-200 difference.
post #6 of 8 (permalink) Old 05-14-2014, 04:28 AM Thread Starter
Ok so my BD Diesel Exhaust manifold have 2 ports for the pyrometer.
One is just outside cylinder 2 and the other is where the manifold is turns in to the up pipe (just beyond cylinder 8).
I am thinking option 2 makes the most sense as most of the exhaust gases are pushed to this one area of the manifold before being sent up though the y pipe. I will get a hotter reading than if I were to place it outside cylinder 2 but I guess it would keep me from having a led foot?
What do you guys think?
Also have a ported intake manifold, intake kit and exhaust all part of my build.
These BD manifolds are also suppose to flow a bit better than the stock manifolds as well.
Thanks again.
HankyD is offline
post #7 of 8 (permalink) Old 05-14-2014, 09:40 AM
Either location is acceptable. 99% of the semis on the road with puris have it post turbo. There are the few hot rods that like to see pre turbo. In the manifolds will give you a higher temp range and it will react faster. I believe about 1300* is tops. After the turbo (where I run mine) will be a little lower in temp. Around 1200* max. And it won't react as fast. However should that pyro probe tip ever decide to break off (I've seen t happen) and your running pre turbo, you will get to replace the turbo. And hope there isn't other damage like metal or oil in the intake. But after the turbo it will just cruse down the exhaust pipe.
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #8 of 8 (permalink) Old 05-14-2014, 02:07 PM
If you have 2 ports on each manifold they are could be for pyrometer and drive pressure.
