Code poped up P0402 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-06-2014, 05:58 PM Thread Starter
Code poped up P0402
JUst poped up at lunch, although I just upgraded my intake and exhaust. 2 weeks ago I put my 4in down pipe, 5in turbo back, 8in tip center dunk over the axle. I had a airaid intake, I sold it adn swaped it out with a stock 2004 intake off another 6.0 powerstroke, w/ a like new filter. The next day I had 2 codes pop up with my intake flow/sensor. Heard it was becuase of my exhaust w/ no tuner. Well yesterday I recieved my S&B dry air intake and no codes poped up after I put this on yesterday night. Well, today at lunch after I warmed my truck up I turned it off becuase I had to go back inside for a last minute thing (didnt notice any codes then), 20mins later I came back out and turned it on again then started driving and my P0402 code poped up (Exhaust gas recirculation flow excessive detected) poped up. Heard it could be a sensor or my egr is ####ed.
I was waiting till I get a little more money till I order my elite diesel egr delete and headstuds with bullet proof water pump. But how do I know if its really messed up and can't go anymore till I delete my egr and everything? I know to check the egr valve and see if its cloged up.
BigRig is offline
post #2 of 6 (permalink) Old 05-06-2014, 06:05 PM
JohnKBrown's Avatar
Re: Code poped up P0402
Well pull your EGR valve and check for wetness and function of the piston section of the EGR valve, next you shine a light back and see if you see any moisture around your EGR. Have you been burning any coolant(recent refill or noticed it drop at all) Usually its pretty noticeable when you start seeing white steam/smoke coming from your exhaust. Good Luck and I hope its just an EGR, would recommend trying a Bulletproof Diesel EGR before going for a full delete.
2006 F250 6.0L Powerstroke (Sold)
1999 F350 7.3L XLT Bone Stock
112,000 Miles
JohnKBrown is offline
post #3 of 6 (permalink) Old 05-06-2014, 06:27 PM Thread Starter
Why are Bulletproof egr and not a full delete?
BigRig is offline
post #4 of 6 (permalink) Old 05-09-2014, 01:02 AM
You can take the egr valve out and if its plugged full of soot, try cleaning it out and running it for a while when its clean. See of the code goes away then.
Triumph1188 is offline
post #5 of 6 (permalink) Old 05-13-2014, 01:41 AM
JohnKBrown's Avatar
Maintain your stock setup and not have to worry about fixing a leaking egr delete or worrying about your fan capability with your EGR unplugged/removed.
112,000 Miles
post #6 of 6 (permalink) Old 05-13-2014, 02:09 AM
whistle tits
ghohouston's Avatar
There's a little bolt hole on the back of the cast intake elbow, and you can bolt the egr valve to it, and still keep it plugged in so you have proper fan clutch operation, and no c.e.l.
ghohouston is offline
