Torque Converter, HPOP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-06-2014, 08:06 AM Thread Starter
Hey guys,
So I am getting pretty close to doing my build. As is stands, I have studs, oem head gaskets, rings, ported intake manifold (Thanks Nate), bullet proof water pump, BD exhaust manifolds, MBRP Y-pipe and turbo back exhaust all either in transit or on hand.
I already have a bullet proof FICM, delete, air intake, coolant filter and all the updates installed.
Just a few more things (they should seem pretty obvious to u guys).
But at what point do I need to upgrade my torque converter? With the tuning that's going to get done (yet to order it) will I need one ? And for those of you who went ahead and bought one, what brand is everyone using?
Are similar priced ones (in the $1000 range) all more or less the same?
And...
I am keeping stock sticks and the stock turbo. With that in mind, do I need to upgrade the HPOP? From what little bit of reading I did on this subject, it's only beneficial with larger injectors... true?
I have some other questions regarding tuning but I will just start a new post.
Thanks
HankyD is offline
post #2 of 3 (permalink) Old 05-06-2014, 03:40 PM
Re: Torque Converter, HPOP
Just my opinion, but if you are keeping stock fuel and stock air you shouldn't need to upgrade.
lenzhotrod is offline
post #3 of 3 (permalink) Old 05-06-2014, 05:17 PM
JGman141
Jgman141's Avatar
The stock hpop will supply far more oil than stock injectors could ever demand, just make sure it's a healthy pump.
Jgman141 is offline
