egr ??????? please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-05-2014, 12:42 AM Thread Starter
martin88's Avatar
egr ??????? please
whats the different ia egr delete and EGR Cooler iam about to dig in to my 6.0l and would like to know which one i should get ?
martin88 is offline
post #2 of 13 (permalink) Old 05-05-2014, 12:48 AM
whistle tits
ghohouston's Avatar
Re: egr ??????? please
An egr delete gets rid of the cooler and valve.
ghohouston is offline
post #3 of 13 (permalink) Old 05-05-2014, 12:53 AM
Jackleg Mechanic
mastrkee's Avatar
Delete = remove or render the exhaust gas cooler inoperable. And remove and block off exhaust gas recirculation valve.
EGR Cooler = a device used to divert exhaust gasses back into the intake manifold. It uses engine coolant to cool down the gasses. The hot exhaust burns out the inside of the device causing coolant to leak into the compression chamber. BOOM bye bye head gaskets.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #4 of 13 (permalink) Old 05-05-2014, 02:05 AM
Big dumb redneck
6speedSD's Avatar
Garage
If you don't have emissions testing, go with the delete and never worry about that ticking time bomb again. If you must have the emissions equipment intact, go with a BPD EGR cooler. Better design than the factory piece.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 13 (permalink) Old 05-05-2014, 02:14 AM Thread Starter
martin88's Avatar
thinking about going with the aFe Blade Runner EGR Cooler but my truck just started to burn anitfreez and white smoking like crazy
martin88 is offline
post #6 of 13 (permalink) Old 05-05-2014, 09:57 AM Thread Starter
martin88's Avatar
so i have been reading up there is a egr cooler bad? to have
martin88 is offline
post #7 of 13 (permalink) Old 05-05-2014, 10:21 AM
Factory EGR coolers are known for their problems. Usually failing and dumping coolant into the intake and engine. EGR valves are know for sticking open and causing running issues. We use the Sinister kit with the preloaded tuner. Helps the engine run cooler and cleaner without the exhaust gas coming into the engine and you get rid of problems that are just waiting to happen. The EGR valve is on the front of the engine right behind the air intake horn where air enters the engine. The EGR cooler is on the passenger side top of engine. It is a tube that runs from the rear of the engine to the front under the intake and brings exhaust gas in to the intake.
Here is the advanced kit with up pipe - MKM Customs 6.0L Ford Powerstroke EGR Delete Kit
Here is the basic kit that is a little easier to use - 6.0L Basic Diesel EGR Delete Kit
Here is the SCT tuner that provides EGR tuning and easy to use for first time 6.0 owners - SCT Tuner SF3 3015 Power Programmer/Tuner
simmy952 is offline
post #8 of 13 (permalink) Old 05-05-2014, 01:28 PM
cope102's Avatar
So does the basic kit really do anything for the motor? If so what does it do?
2004 F350 DRW FX4 Banks Six Gun Tuner,Egr delete, Adrenaline pump, Banks air, 4 inch straight pipe exhaust
cope102 is offline
post #9 of 13 (permalink) Old 05-05-2014, 02:13 PM
whistle tits
ghohouston's Avatar
Keeps you from burning coolant, and possibly blowing a head gasket
post #10 of 13 (permalink) Old 05-05-2014, 02:42 PM
Or weld up both ends on your EGR cooler and leave it in place.
lenzhotrod is offline
