6.0 heads - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-02-2014, 11:43 PM Thread Starter
stroke05's Avatar
6.0 heads
I got an 05 6.0. And I need another set of heads are 06 heads the same and direct fit for an 05? Or are they a little different.
stroke05 is offline
post #2 of 7 (permalink) Old 05-03-2014, 01:43 AM
Re: 6.0 heads
Any of the heads will fit. The only difference might be the alignment dowels.
lenzhotrod is offline
post #3 of 7 (permalink) Old 05-03-2014, 01:27 PM
Guest
Re: 6.0 heads
I recommend getting the ARP studs while your at it if you don't already have them.
xxxxxxxxxxxxxxxRed-0-4 is offline
post #4 of 7 (permalink) Old 05-03-2014, 04:34 PM Thread Starter
stroke05's Avatar
Re: 6.0 heads
I have them already they were on old heads
stroke05 is offline
post #5 of 7 (permalink) Old 05-03-2014, 09:11 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: 6.0 heads
I recall the Ford head gasket kit now has both sets of dowels. So no matter what heads are used you have the parts to make them fit.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #6 of 7 (permalink) Old 05-03-2014, 10:42 PM
Re: 6.0 heads
trucks built after 1-15-06 have 20mm dowel pins the bolt pattern for rocker carrier is also different. 20mm heads really should use 06+ rocker carrier you don't reuse any bolts to hold down the carrier but they are used for proper alignment
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #7 of 7 (permalink) Old 05-04-2014, 02:39 AM
Re: 6.0 heads
The rocker box on the later models just don't use all the bolts. Still interchangeable.
