how to tell if a 6.0 already has egr delete & studs have been done - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-01-2014, 06:44 AM Thread Starter
cope102's Avatar
How does one tell if an egr delete & head studs have been done on a truck? and does anyone have pics they can post for newbie?
2004 F350 DRW FX4 Banks Six Gun Tuner,Egr delete, Adrenaline pump, Banks air, 4 inch straight pipe exhaust
cope102 is offline
post #2 of 9 (permalink) Old 05-01-2014, 08:15 AM
jtgf250's Avatar
Re: how to tell if a 6.0 already has egr delete & studs have been done
Look at the bottom side of each head. If you see a stub and 12 point nut, then studs. If you just see a bolt head then its not. For egr, look at the passenger side down in the valley. If you don't see a large round or square tube( depends on years) from front to back and just see a small pipe, then it deleted.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 9 (permalink) Old 05-01-2014, 01:52 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
whs!^^^ you can see the front lower head bolt/stud on each side. one under the pass. alternator & one under the intake.
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #4 of 9 (permalink) Old 05-01-2014, 02:01 PM
Turd-250's Avatar
here's a cool reference pic. you'll be able to see the front lower one right under the alternator:
lol here's another cool one of the same engine before he swapped in the studs. you can see that front lower (drivers side) right under the t-stat housing & intake:
edit: wrong pic
edit: this one does ok i s'pose:
Turd-250 is offline
post #5 of 9 (permalink) Old 05-01-2014, 02:04 PM
jfarmer86's Avatar
hiii turd
jfarmer86 is offline
post #6 of 9 (permalink) Old 05-01-2014, 02:44 PM
Turd-250's Avatar
sup farmer!
Turd-250 is offline
post #7 of 9 (permalink) Old 05-02-2014, 07:23 AM Thread Starter
cope102's Avatar
Thanks turd
cope102 is offline
post #8 of 9 (permalink) Old 05-02-2014, 03:23 PM
Turd-250's Avatar
np! i like looking up pictures anyhow lol
Turd-250 is offline
post #9 of 9 (permalink) Old 05-06-2014, 05:26 AM Thread Starter
cope102's Avatar
lol.. well i have a delete kit but no studs i have mine torn down now due to an hpop leak old style pump.. so i ordered an adrenaline pump... and thinking ill go ahead and do studs too.. sugest anything else while im into it all/
cope102 is offline
