Bad hpop? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 04-28-2014, 09:34 PM Thread Starter
cope102's Avatar
Bad hpop?
My hpop is showing 5.7 psi at crank. I believe it's suppose to bee at 500. Anyone know? Should I change the stc fitting out or go ahead and change the whole pump? Or could I change the ipr. Out? It's only showing code for low icp and I've changed the icp... any suggestions?
2004 F350 DRW FX4 Banks Six Gun Tuner,Egr delete, Adrenaline pump, Banks air, 4 inch straight pipe exhaust
cope102 is offline
post #2 of 16 (permalink) Old 04-28-2014, 10:05 PM
JGman141
Jgman141's Avatar
Re: Bad hpop?
Try to unplug the icp sensor and see what it does. If it's still the same problem id switch out your ipr
Jgman141 is offline
post #3 of 16 (permalink) Old 04-28-2014, 10:52 PM
Re: Bad hpop?
If you have a 2004 like your sig says, you don't have the stc fitting. That was only 2005-07 MY.
Triumph1188 is offline
post #4 of 16 (permalink) Old 04-29-2014, 04:00 AM
Juniorssrollin's Avatar
Re: Bad hpop?
Unless he has a late build 2004. Then you would have same setup as 05-07
2005 F350 CCLB FX4
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
post #5 of 16 (permalink) Old 04-29-2014, 06:51 AM Thread Starter
cope102's Avatar
Re: Bad hpop?
from what ive read since this post none of the 04 have the stc fitting whether that is correct or not i dont know.. I took icp out and cranked and still not start.. Im going to pull my ipr and see what the screen looks like on it this week when i am off.. Thanks for the help.
cope102 is offline
post #6 of 16 (permalink) Old 04-29-2014, 09:33 AM
JGman141
Jgman141's Avatar
Re: Bad hpop?
You don't want to fully pull it out, you just want to unplug it and them try to crank to see of it will go.
Jgman141 is offline
post #7 of 16 (permalink) Old 04-29-2014, 10:15 AM
whistle tits
ghohouston's Avatar
Re: Bad hpop?
Is your dash oil pressure gauge coming up while cranking? If not, pull the oil filter, and press down on the small black spring loaded drain in the bottom of the filter housing. If the housing fills up decently quick, your lpop is probably okay, but if it won't fill, your lpop may need to be replaced, and hopefully you don't find needle bearings in it.
ghohouston is offline
post #8 of 16 (permalink) Old 04-29-2014, 11:50 AM Thread Starter
cope102's Avatar
Re: Bad hpop?
Oil pressure gauge does not move when I crank it. I will try that with the filter when I'm off work this weekend. Thank you for the tip!
cope102 is offline
post #9 of 16 (permalink) Old 04-29-2014, 11:52 AM Thread Starter
cope102's Avatar
Re: Bad hpop?
Jgman, I said that wrong I unplugged the icp and cranked and still the same....
cope102 is offline
post #10 of 16 (permalink) Old 04-29-2014, 12:21 PM
Jackleg Mechanic
mastrkee's Avatar
Re: Bad hpop?
What are you reading hpo pressure with. Its been a while since I used my Banks monitor but iirc it reads x 100, ie 5.7= 570
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
