Rpm limit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-16-2014, 10:52 PM Thread Starter
Rpm limit
Hey guys was just wondering what the "redline" is for our 6.0. and how they handle the upper rpm's in stock form.
05 F250, 6Spd, 4" turbo back Magnaflow Duals, No cat. No muffler, Egr delete, Intake, SCT X4
bronco3512 is offline
post #2 of 12 (permalink) Old 04-17-2014, 06:33 PM
YZ250F12154's Avatar
Re: Rpm limit
I believe redline is 4200 or so if I remember my gauge correctly. My truck hasn't been stock for a while so I can't say how it handles the upper RPM range in that form.
2004 6.0 Powerstroke
5" MBRP Turbo Back Straight Pipe Exhaust
SCT Livewire - IDP Extreme Street Tune
58V FICM
Blue Spring
YZ250F12154 is offline
post #3 of 12 (permalink) Old 04-17-2014, 09:35 PM
Re: Rpm limit
If I recall the 2003 is about 250 RPM's higher than the later models. A custom tune can adjust this.
lenzhotrod is offline
post #4 of 12 (permalink) Old 04-20-2014, 02:06 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Rpm limit
High rpms in a stock 6.0 runs the risk of valve/piston contact. I wouldn't advise it...
Do a quick google search. Leaves a perfect valve imprint in the top of the piston.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 12 (permalink) Old 04-21-2014, 10:38 PM Thread Starter
Re: Rpm limit
Thanks, I don't plan on cranking it any where near 4200. I don't think I have gotten past 3300. that just seems too high for a diesel. Just wanted an idea of where these engines like to run. Runs great from 1000-2500 rpm, but,My truck seems to bog after 2500 rpm. Is that normal?
post #6 of 12 (permalink) Old 04-23-2014, 02:51 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Rpm limit
Under 2500 is your torque curve.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #7 of 12 (permalink) Old 04-23-2014, 03:11 AM
Re: Rpm limit
Stock trucks definitely seem to run better down low. My truck's sweet spot seems to be around 2700-2800 now with a little bit of work done.
58V FICM
Blue Spring
post #8 of 12 (permalink) Old 04-26-2014, 01:38 AM Thread Starter
Re: Rpm limit
good stuff guys, thanks.
post #9 of 12 (permalink) Old 04-26-2014, 01:41 AM
96powerstroker's Avatar
Re: Rpm limit
That's what I never liked about 6.0s they lack the low low end of torque
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #10 of 12 (permalink) Old 03-09-2016, 11:33 PM
local idiot
ServiceTech's Avatar
Re: Rpm limit
???????? I don't I know about all yall but ive hit over 3900
ServiceTech is offline
