Should I upgrade my fuel pump? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-14-2014, 04:29 AM Thread Starter
So looks like my old fuel pump is dead. Just looking for some ideas on what do.
Should I replace it with a stock unit or upgrade to a air dog 2?
Truck is a 2004 6.0 with 175,000 miles
And has blue spring upgrade
In the future I'm going to get bigger injectors 190cc and bigger turbo.
And feed back would be great
Thanks
Tj561CO is offline
post #2 of 11 (permalink) Old 04-14-2014, 07:10 AM
2Dstorm's Avatar
Re: Should I upgrade my fuel pump?
Ad2 is no good on a 6.0
I
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #3 of 11 (permalink) Old 04-14-2014, 11:52 AM
JGman141
Jgman141's Avatar
Airdog 2 is a down grade
Jgman141 is offline
post #4 of 11 (permalink) Old 04-14-2014, 03:40 PM
Good ol boy
04 f350's Avatar
I'm almost positive my stock pump could've kept up with these 205s as good and my air dog 2 has, like stated above it is a massive downgrade, especially for the money. Terrible design.
Studded and Deleted
5 inch axle dump
Back Road Performance Tuned
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #5 of 11 (permalink) Old 04-14-2014, 08:12 PM Thread Starter
That's guys stock fuel pump it is
Tj561CO is offline
post #6 of 11 (permalink) Old 04-16-2014, 11:20 AM
Swamp trash...
Merc82's Avatar
+1 for stock pump. Plumb a lift pump before it.
Chris. 06 LBCC XL 4◊4
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #7 of 11 (permalink) Old 04-16-2014, 12:15 PM
Which lift pump? Id like to plumb in one but unsure.
Eddy is offline
post #8 of 11 (permalink) Old 04-16-2014, 01:25 PM
Good ol boy
04 f350's Avatar
The air dog 150s have had good success and a low failure rate I would run that, get a sump kit and be done with it, you'll have somthing reliable then.
Studded and Deleted
5 inch axle dump
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #9 of 11 (permalink) Old 04-16-2014, 01:55 PM
2Dstorm's Avatar
I run an ad150 inline before stock pump works great... Plus if the ad150 goes down the stock pump will pull thru it and get you home. The benefits to having the ad 150 are the same as the ad2 just no regulator. But the stock pump will only push 65psi I have a regulated fuel return also. I keep it around 62psi feeds my 175/75's just fine zero drop at wot
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #10 of 11 (permalink) Old 04-20-2014, 02:09 AM
Big dumb redneck
6speedSD's Avatar
Garage
6.4 pusher does the same thing, but cheaper....am I right?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
