Bigger turbo challenges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 42 (permalink) Old 04-13-2014, 10:45 PM Thread Starter
Thought I'd start a thread since there may be others out there trying to tackle the same issues. Installed a MadMax turbo a couple of weeks back. Trying to get closer to 500hp on stock sticks. 0-60 times have improved but EGTs are really high and mileage has dropped. I'm in Colorado at around 5500ft elevation.
Thinking of getting an aftermarket intake and maybe a ported intake manifold to improve the EGTs and make better use of the fuel at the low end. Been working with a couple of tuners, its helped but the files make the truck run funky. Great guys here and we're still working the issues. Any input would be great. Especially on the value of an aftermarket CAI and a ported intake manifold.
Some specifics. 0-60 boosted rear wheel launch improved time from 7.0 to 6.4 seconds. 0-30 time has dropped about 0.5sec but the high end is screaming fast. EGTs can climb to 1300F just going up a slight incline at 40mph. Fuel economy (comparing lie-o-meter readings) has dropped 1-2 mpg.
2005 F-350 CCLB Dually. ARP Headstuds, Bulletproof EGR Cooler, upgraded H/P oil system, Blue Spring, Sinister Diesel cooling system filter, Bulletproof 48V FICM power supply. Banks monster exhaust, kitty lost along the way. MadMax Turbo, WPE Stage II ported intake manifold, PHP FICM tuning.
MaxQ Dually is offline
post #2 of 42 (permalink) Old 04-13-2014, 10:47 PM Thread Starter
Re: Bigger turbo challenges
Sorry, meant to say 0-30 times have INCREASED 0.5 sec. I don't think I have enough air to burn the fuel.
post #3 of 42 (permalink) Old 04-13-2014, 11:36 PM
Big dumb redneck
6speedSD's Avatar
Garage
Seems to me if you have a bigger turbo, then you have plenty of air for stock sticks. Any spooling issues?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 42 (permalink) Old 04-14-2014, 01:38 AM Thread Starter
Yes. Lots of lag using a custom tune I have from my stock turbo. Truck will sit still for a 2 count at a dead stop then spit out a lot of smoke before taking off. Really moves out after about 2200rpm. Cruising at 45mph will get me high EGTs while a WOT run will not get above 1150F.
post #5 of 42 (permalink) Old 04-14-2014, 01:44 AM
Big dumb redneck
6speedSD's Avatar
Garage
How big is that Madmax? Sounds to me like you have too much turbo. Lower rpms just can't spool it, but higher rpms will...that's why your EGT's are so out of whack. Just my opinion anyways.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #6 of 42 (permalink) Old 04-14-2014, 02:14 AM
JGman141
Jgman141's Avatar
You need to have your tune adjusted for that new turbo, the mad max is a 66mm turbo and needs to have the vgt duty cycle higher down low to improve spool. Give drew at back roads performance a call, he has a tune specifically for that turbo.
Jgman141 is offline
post #7 of 42 (permalink) Old 04-14-2014, 02:15 AM Thread Starter
From the MTW website:
Housing Specs & a/r: 66mm / 90mm / .58a/r
Compressor Wheel: 66mm billet slimline
Turbine Wheel: 10 balde PowerMax
Compatible Injectors: Stock - 190cc
post #8 of 42 (permalink) Old 04-14-2014, 02:48 AM
Roenicke95stroker's Avatar
I'm out In eagle. We need to get a meet an greet going.
Roenicke95stroker is offline
post #9 of 42 (permalink) Old 04-14-2014, 10:28 PM
Super Diesel's Avatar
What transmission do you have? I've got the MadMax too, and I'm not building much boost until about 1800 RPMs. I've got a ZF6 tranny though... as well as generic tunes from Matt @ Gearhead. I'm not running a MadMax specific tune yet. However, there's a guy named Drew (Back Road Performance) who makes a great tune for the MadMax and stock injectors from what I hear. Try giving him a call to see what he can do for you. He sent me one last night, but my truck is down getting a full fuel system installed.
Getting ready for 190/75s
Chris|2006 F-250 RCSB
Super Diesel is offline
post #10 of 42 (permalink) Old 04-14-2014, 10:30 PM
fueled by Colecovision
golfer's Avatar
Garage
have your tuner(s) focus on shift points & converter lock/unlock strategy..
or see for yourself..play around with the OD/Tow Haul or whatever it's called.
golfer is offline
