Degas Cap Leak? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-10-2014, 03:41 PM Thread Starter
YZ250F12154's Avatar
Degas Cap Leak?
I opened my hood this morning just to take a look and found that my degas bottle was a mess. Obviously I've had some liquid running all over it since there is white residue left behind. Any thoughts?
2004 6.0 Powerstroke
5" MBRP Turbo Back Straight Pipe Exhaust
SCT Livewire - IDP Extreme Street Tune
58V FICM
Blue Spring
YZ250F12154 is offline
post #2 of 6 (permalink) Old 04-10-2014, 03:59 PM
jfarmer86's Avatar
Re: Degas Cap Leak?
Either a compression leak into the cooling system caused by a warped head... Exhaust gasses from a failed egr cooler.
Those are the two most common issues since it looks like yours is spewing I would say its more than a cap issue..
You'll need to hook a gauge up to the coolant hose that comes off the intake to the degas and read the pressures.... If you are on a hard acceleration and it is spiking then goes back down would be a egr if it goes up and stays up then a head issue.. Anything past 12 psi is no bueno
jfarmer86 is offline
post #3 of 6 (permalink) Old 04-10-2014, 04:27 PM
Re: Degas Cap Leak?
Here is a video that will give you a visual on how to check it. ( It's what jfarmer86 just described )
6.0 Ford powerstroke diesel head gasket and oil cooler diagnostic tips - YouTube
2006 F-250 6.0 Auto CC SB 4x4
charlez is offline
post #4 of 6 (permalink) Old 04-10-2014, 04:30 PM
Re: Degas Cap Leak?
annnnnd another 6oh head gaskets bite the dust.
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #5 of 6 (permalink) Old 04-12-2014, 07:33 AM
06 CC SB Lariet
Natos's Avatar
Re: Degas Cap Leak?
I am not a mechanic, so I won't try to guess why your degas cap leaks. But I did find this worth while...
Watch "$5 PART WILL SAVE YOUR POWERSTROKE FROM SELF DESTRUCTION" on YouTube
$5 PART WILL SAVE YOUR POWERSTROKE FROM SELF DESTRUCTION - YouTube
Natos is offline
post #6 of 6 (permalink) Old 04-13-2014, 10:32 PM Thread Starter
Re: Degas Cap Leak?
Thanks for all of your input guys, I really appreciate it. So far it's alive and well, no more leaking. I have plans to get it bulletproofed this summer once I start my big boy job after college, so I'm trying to baby it until then!
58V FICM
Blue Spring
