Couple ?'s on Tunes/Studs/Head Gaskets... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 04-08-2014, 03:42 AM Thread Starter
brodyman0508's Avatar
Like the title says I've got a couple concerns on modding my truck. It's an 04 F250 SC SB FX4 with 158,XXX.. So far I've added straight pipe (3.5"), and a drop in AirRaid dry filter. I want to add a Livewire TS with custom tunes in the worst way ha.. When I bought the truck from a local Ford Dealer I had them pull the carfax on it and it shows where the truck was worked on under warranty with 17,000 miles on it.. The transmission was replaced,Head gaskets and studs, and FICM was replaced.. With all that done 140,000 miles ago it hasn't had any other major work done. Do y'all think it's be safe to run custom tunes on it? It's mostly a daily driver that'll occasionally pull our camper and tractor and equipment once deer season gets here.. Thanks for the input
brodyman0508 is offline
post #2 of 26 (permalink) Old 04-08-2014, 03:51 AM
2Dstorm's Avatar
Re: Couple ?'s on Tunes/Studs/Head Gaskets...
If the truck is studded custom tunes should be fine. I recommend Drew's rapped ape tune you will love it. Some other mods you will want to put on the list are
Coolant filter system
Elc coolant
Blue spring kit or regulated fuel return
6.4 banjo bolts
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #3 of 26 (permalink) Old 04-08-2014, 03:56 AM Thread Starter
Drew is at Backroad Performace?
post #4 of 26 (permalink) Old 04-08-2014, 04:04 AM
2Dstorm's Avatar
Yes you can probably catch now (317) 522-8448
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #5 of 26 (permalink) Old 04-08-2014, 04:05 AM
2Dstorm's Avatar
FYI he is an sct dealer also
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #6 of 26 (permalink) Old 04-08-2014, 04:07 AM Thread Starter
Alright thanks..
post #7 of 26 (permalink) Old 04-08-2014, 07:47 AM
"Slap hands slap hands"
FlossyB's Avatar
Elc coolant
6.4 banjo bolts
if the truck isn't studded he can write custom tunes for you as well I have his economy/towing tune I love it.
JB
FlossyB is offline
post #8 of 26 (permalink) Old 04-09-2014, 01:01 AM Thread Starter
It did have the gaskets and bolts replaced but I'm assuming it was OEM Ford products.. Not certain about that though.. Does that make a difference?
post #9 of 26 (permalink) Old 04-09-2014, 01:12 AM
JGman141
Jgman141's Avatar
There's a big difference between a truck that has factory head bolt and aftermarket studs. Factory head bolts are weak and let the head lift off the block easier than studs do.
Jgman141 is offline
post #10 of 26 (permalink) Old 04-09-2014, 01:22 AM Thread Starter
I reckon I'll just have to put the funds back for ARP studs and another set of gaskets, just in case.. Because I'm definitely throwing a tuner on it. Ordering it Friday.. Now I have to decide which tunes to get.. I've searched and read and searched some more and I really can't find any bad things about any of the more popular ones used on here. Any personal preference of one over the other?
