Any Ideas?? Rough Idle after 175cc inj. and powermax turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-24-2014, 07:00 PM Thread Starter
Okay... 2006 Ford F250 6.0L II Stage 1 175cc injectors, Powermax Turbo, Sinister regulated return, innovative tunes, studded, deleted, MANUAL transmission. Problem: The truck fires up and runs great until it get to operating temp and then develops a random misfire. any load factor on the engine will get rid of it, and the truck runs great, except its pretty smokey and the miss at idle. Pressing the brake pedal down hard is enough load to correct the idle problem. Please feel free to help! Thanks!
terryc is offline
post #2 of 16 (permalink) Old 03-24-2014, 07:30 PM
jfarmer86's Avatar
Re: Any Ideas?? Rough Idle after 175cc inj. and powermax turbo
Pressing the brake gets rid of the miss??
jfarmer86 is offline
post #3 of 16 (permalink) Old 03-24-2014, 07:35 PM
richyrich's Avatar
Yep just like any other car u hit the breaks while its idling and the engine gets a slight load and raises the rpms by like 50 or something like that lol
2002
f-250 7.3L powerstroke superduty xlt sc sb 4x4 offroad, pure turbos 360 turbo rebuild kit,
mile marker 449 s/s hub locks, php phoenix 6 position chip, diy 6637 intake, 140k and rollin strong
richyrich is offline
post #4 of 16 (permalink) Old 03-24-2014, 07:43 PM Thread Starter
Well..the power steering pump loads the engine when brake is pressed. Actually the Rpm drops a bit, and idle smooths right out. Also if you kill the engine, and then start it back up it will idle fine until you touch the throttle, and if rpms go up, they come back down but never really level out again.
terryc is offline
post #5 of 16 (permalink) Old 03-24-2014, 07:44 PM
jfarmer86's Avatar
Wouldn't that be more of a gas deal because of vacuum?
Raising the RPMS by 50 still shouldn't get a miss to clear out cause the only thing that would do would slightly bring up rail pressure. And with that small of injectors I wouldn't think the stock hpop would be starving out in the rails.
post #6 of 16 (permalink) Old 03-24-2014, 07:45 PM
jfarmer86's Avatar
Ahh see forgot about the pump feeds the booster.
post #7 of 16 (permalink) Old 03-24-2014, 07:55 PM
06-6.0 stoker's Avatar
Pretty good chance it's the tuning.
Sent from AutoGuide.com App
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #8 of 16 (permalink) Old 03-24-2014, 07:56 PM
Good ol boy
04 f350's Avatar
Who's injectors? Misfiring or loping?
Studded and Deleted
5 inch axle dump
Back Road Performance Tuned
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #9 of 16 (permalink) Old 03-24-2014, 08:24 PM
2Dstorm's Avatar
Better call drew I think you have a tuning issue
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #10 of 16 (permalink) Old 03-24-2014, 10:42 PM
Swamp trash...
Merc82's Avatar
What he said...plugged spill ports?
Chris. 06 LBCC XL 4◊4
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
