Stage 2 cam??????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-24-2014, 02:34 PM Thread Starter
Cool Stage 2 cam???????
Currently torn down awaiting headstuds..... Have the following going into it, Elite diesel 155 injectors, garrett powermax, arp studs, have mbrp turbo back, banks intercooler, afe intake, 65psi fuel spring mod, FASS fuel system going in. My question is... has anybody tried out the stage 2 cam from DFC or Colt Cams and if so what were the results?
Mounkey Nuts is offline
post #2 of 8 (permalink) Old 03-24-2014, 05:58 PM
Stroke it B!tch
fordboy11's Avatar
Re: Stage 2 cam???????
Sub'd I'd like to hear some more on the cam's but I do know that for a mild motor like what you have a stock is more than ok.
78 F-150 300 straight 6, 3 on the tree
03 F-250 6.0 Play toy
06 F-250 6.0 (general nightmare) 2.5 pulling truck
12 F-350 6.7 Tow rig
Gotta pay to play son!
Originally Posted by F-250-Owner View Post
I know you said you wouldnt turn it up..... but come on.... its like saying "I promise I will only stick the tip in" never happens like that
fordboy11 is offline
post #3 of 8 (permalink) Old 03-24-2014, 06:10 PM
jfarmer86's Avatar
You can't just simply throw a cam into a motor, you would have to have a lot behind it to make it worth the money to start going behind it. I'm currently building a bottom end for a truck that's going to have one. But its also .40 over mahle pistons forged rods lifters push rods ported heads etc. Going to be a expensive long block
jfarmer86 is offline
post #4 of 8 (permalink) Old 03-24-2014, 06:25 PM Thread Starter
Thanks for the input! Probably will stick with stock cam and invest the money elsewhere.
post #5 of 8 (permalink) Old 03-24-2014, 10:53 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
My opinion is if you're going to spend $400-$500 on a stock cam, I'd most definitely pay $600 for a Stage 1 cam and not care if I got anymore power or not . JMO though.
Nate
windrunner408 is offline
post #6 of 8 (permalink) Old 03-25-2014, 01:22 AM
never done just cam swap, only cams I have changed have been in full rebuilds. But if your looking at stage 2 cams keep in mind piston to valve clearance is tight may require cutting the pistons.
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #7 of 8 (permalink) Old 03-25-2014, 07:09 AM
I'm pretty sure anything from elite that is over a stage one requires pistons to be cut or the valves will hit. Which is an expensive additional cost to the cam itself.
Triumph1188 is offline
post #8 of 8 (permalink) Old 03-26-2014, 02:45 AM
Yep. the stage 2's I put in we used cut coated pistons
wise guy is offline
