Aftermarket sensor placement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-13-2014, 07:48 PM Thread Starter
Weatherlite's Avatar
Garage
I've got a boost and a tranny temp sensor I need to place. For the boost, is there already a place I can use on the manifold or will I have to drill and tap the CAC tube? As for the tranny, do I just T off where the stock sensor goes on a 5R110 or is there an alternative? Did a little searching and didn't find the answer, but I'll keep looking.
Weatherlite is offline
post #2 of 10 (permalink) Old 03-13-2014, 08:32 PM
Administrator
Zmann's Avatar
Re: Aftermarket sensor placement
here
http://www.dieselmanor.com/installations/default.asp
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 10 (permalink) Old 03-13-2014, 10:09 PM
Big dumb redneck
6speedSD's Avatar
Garage
^^^ much easier than trying to explain where.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 10 (permalink) Old 03-13-2014, 10:49 PM Thread Starter
Garage
That works! Thanks. Though when I got the reply and went looking I found that there isn't a customer access harness anywhere to be found. And I pulled panels off, reached up inside, traced every harness, etc. My only thought is the previous owner had used it for something and then when he removed the accessory he either tucked it into a black hole or cut the damn thing off somewhere. I got what I needed though. :) Gauges are hooked up, just have to install the sensors now.
post #5 of 10 (permalink) Old 03-13-2014, 11:00 PM
Administrator
Zmann's Avatar
the customer access wires are thoughtful but just as easy to run a new wire IMHO than find both ends of those and have a connector at both ends
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 10 (permalink) Old 03-14-2014, 02:50 AM Thread Starter
Garage
I wound up pulling the fuse panel and pulled the fuse labeled as "Customer Access". I then pulled the connectors off the back and did a continuity check to find the pin. Found the correct wire and used that as my switched power. And yes, I used the wire that comes AFTER the fuse, not the lead that's hot going into the fuse. As for unswitched, I just tapped into the cigarette lighter power. It's rated at 10 amps and I never use the thing anyway. Ground was easy and using the recommended wire on that site for my illumination source I was able to get the gauges all hooked up electrically. I did the fuel pressure sensor (which is a bit of a pain without taking off a bunch of crap) and will get the trans temp tomorrow....maybe boost as well. EGT will have to wait until I get the top end torn apart and have the turbo removed (top end as in turbo, oil cooler, hoses, etc) so I don't have to worry about leaving drill shavings inside the exhaust which might get into the turbo's inner workings.
Thanks for the help guys!
post #7 of 10 (permalink) Old 03-14-2014, 03:00 AM
Banned
Nice link Zmann!
miller45103 is offline
post #8 of 10 (permalink) Old 03-14-2014, 01:18 PM
Administrator
Zmann's Avatar
i use that link so much i feel like i need to buy something lol
it was decent of them to spend the time on those articles IMHO
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 10 (permalink) Old 03-15-2014, 02:39 AM Thread Starter
Garage
I have to admit, those pictures they provided are invaluable! Trans port was easy to find because of the pic. Without it, I would have been looking all over the darn thing trying to figure out what was what. The hardest part of doing the trans temp and boost sensors was torquing down the intake elbow to the right torque. 23 ft-lbs just seems like so much for those little bolts!
post #10 of 10 (permalink) Old 03-15-2014, 11:35 PM
Big dumb redneck
6speedSD's Avatar
Garage
It's not those little bolts you have to worry about. It's the fact that you are threading them into an aluminum intake. Easy to booger up those threads if you overtighten.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
