p0407 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-13-2014, 04:14 PM Thread Starter
jhunter14's Avatar
p0407
So I installed my new Livewire ts and am just runnin the canned performance tune right now for the time being.
But now I dont hear the turbo whistle at all at an idle like I used to and its throwing the p0470 code now.
Any input?
2006 F-250 XLT 6.0L 4x4 CC Auto, 8X,XXX miles: 6.4 banjos, RR blue spring, ARP's, EGR delete, STC update, digital FP gauge, SCT Livewire TS, coolant filter, S&B CAI, CFM Smallmouth, 5" straight pipe with 8" tip. Updated turbo feed/drain.
jhunter14 is offline
post #2 of 8 (permalink) Old 03-13-2014, 05:45 PM Thread Starter
jhunter14's Avatar
Re: p0407
P0470
NOT P0407...
post #3 of 8 (permalink) Old 03-13-2014, 07:20 PM
duck fan's Avatar
Re: p0407
P0470 is an Exhaust Back Pressure Sensor Circuit Error. Check the plug to the EBPS and the sensor itself. If you have a way to monitor live data, look and see what the EBPS is showing with the key on and the engine off.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #4 of 8 (permalink) Old 03-13-2014, 10:47 PM Thread Starter
jhunter14's Avatar
Re: p0407
Key on and engine off it is reading right at 143Hg
post #5 of 8 (permalink) Old 03-14-2014, 04:52 AM
duck fan's Avatar
Re: p0407
Funny that it reads Hg instead of PSI. 143Hg = 70.23psi. KOEO, the EBPS should read about 14psi depending on the elevation you live at. Sounds like either the sensor is bad (most likely) or the wiring is bad (Less likely).
duck fan is offline
post #6 of 8 (permalink) Old 03-14-2014, 11:14 AM Thread Starter
jhunter14's Avatar
Re: p0407
I can change the readout to psi. I just checked real quick. I'll check out connection and wiringc then I'll breplace it if all checks out.
post #7 of 8 (permalink) Old 03-14-2014, 11:16 AM Thread Starter
jhunter14's Avatar
Re: p0407
Would this sensor going bad give me more turbo lag upon acceleration? And like I say, the turbo doesn't whistle at idle like before..
post #8 of 8 (permalink) Old 03-18-2014, 02:59 AM
duck fan's Avatar
Re: p0407
It will cause all sorts of issues. Your fuel mileage has probably dropped as well.
duck fan is offline
