egr delete, kind of.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-13-2014, 12:42 AM Thread Starter
06 FX4,4" Rough Country
Bleed Blue's Avatar
ive read where guys "delete" their egr by using their programmer and never popping the hood and im wondering how effective this is? i have a tuner and can do it, just wondering if it even matters and what it does, since the egr is still there. also what about unplugging the egr too?
06 F250 CCLB FX4, 173K, Egr delete, Blue spring, SCT performance tune, AFE cold air, 4" Rough Country, 35x12.50 Cooper STT m/t, Fuel Hostage 18x12 -44 offset, 4"dp into 5" Diamond Eye system
Bleed Blue is offline
post #2 of 9 (permalink) Old 03-13-2014, 12:58 AM
Re: egr delete, kind of..
Turning off egr will keep soot out of intake and egr cooler will stay cool "no egr flow"
Keep the valve plugged in.
Its a good place to start, eliminates many of egr related issues, But problem is cooler can still leak.
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #3 of 9 (permalink) Old 03-13-2014, 12:58 AM
PursuitInterceptor
HeavyAssault's Avatar
I'm not a fan of using the tuner alone. You need to block the exhaust gases from entering the EGR cooler. Easy step would be to block the up-pipe connection at the rear of the EGR cooler.
Using the tuner is said to limit the EGR valve operation thus limiting the amount of exhaust entering the EGR cooler.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #4 of 9 (permalink) Old 03-15-2014, 12:59 AM Thread Starter
Bleed Blue's Avatar
Hhmm, so now I'm stuck between doing an not with those two responses...one sounds good and one sounds bad?
post #5 of 9 (permalink) Old 03-15-2014, 01:04 AM
'05 Excursion
Term3's Avatar
A tired EGR valve can be forced open by boost in the low thirties.
Sent from AutoGuide.com App
Term3 is offline
post #6 of 9 (permalink) Old 03-15-2014, 01:45 AM
egr flow is hard on the engine if you have a tuner simplest thing to do is turn it off FREE simply select off with your sct device, a good place to start. after that next thing to do is eliminate the chance of the cooler leaking by replacing it or deleting it. If you do delete it EGR will still need to be turned off
wise guy is offline
post #7 of 9 (permalink) Old 03-15-2014, 07:53 PM
IIvonnyII's Avatar
i started with just turning it off in my custom tunes.. worked well, then whenever later on down the road i deleted it. better to start like that then to not
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #8 of 9 (permalink) Old 03-16-2014, 02:25 PM Thread Starter
Bleed Blue's Avatar
well i turned off the egr yesterday and gave it a higher idle while i was at it. is the only advantage to the high idle that u can hear the turbo better then?
post #9 of 9 (permalink) Old 03-16-2014, 06:21 PM
'05 Excursion
Term3's Avatar
Your heater and your A/C will probably work better. I set my idle up higher in the winter.
Term3 is offline
