Going in for the kill, EGR! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-09-2014, 09:04 PM Thread Starter
PBUX690
Welp, I believe my deltas are far enough to go in and replace the oil cooler. While I am in there, I was going to delete the egr, do standpipes, dummy plugs, and stc fitting. Is there anything that yall suggest to replace or add while I am in /around that area?? Im going to IPR egr delete, and OEM oil cooler/gaskets/standpipes/dummyplug/stc fitting. Thanks for the suggestions!
pbuxton11 is offline
post #2 of 17 (permalink) Old 03-10-2014, 12:12 AM
"Slap hands slap hands"
FlossyB's Avatar
Re: Going in for the kill, EGR!
I would just knock out the 6.4 banjo bolts, coolant filter and blue spring kit while your in there doing the work.
JB
FlossyB is offline
post #3 of 17 (permalink) Old 03-10-2014, 12:29 AM
Swamp trash...
Merc82's Avatar
Sounds like a good plan bud how 'bout a coolant flush before you replace that cooler as well?
Chris. 06 LBCC XL 44
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #4 of 17 (permalink) Old 03-10-2014, 12:51 AM
FlossyB's Avatar
that a must in my opinion as well
JB
FlossyB is offline
post #5 of 17 (permalink) Old 03-10-2014, 01:12 AM
Swamp trash...
Merc82's Avatar
Little tip on the coolant flush, buy the fumoto valves and install 3/8 line on them, they make life sooo much easier. Makes draining the block as easy as turning the valve.
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #6 of 17 (permalink) Old 03-10-2014, 02:32 AM Thread Starter
PBUX690
Yeah that is def a must! What about this oil drain tube i've heard about?
post #7 of 17 (permalink) Old 03-10-2014, 02:50 AM
Swamp trash...
Merc82's Avatar
Oil drain tube? Possibly the turbo oil drain tube?
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #8 of 17 (permalink) Old 03-10-2014, 03:06 AM
arp head studs if you have not done then yet. when my oil cooler went, i did everything.
6.0_psd is offline
post #9 of 17 (permalink) Old 03-10-2014, 10:49 PM Thread Starter
PBUX690
Haha, my favorite quote "dont fix something if it aint broke" arp headstuds and gaskets = tack on another $2500.00. Thanks for the input, but that wont be happening this go around
and yes turbo oil drain tube, thoughts??
post #10 of 17 (permalink) Old 04-26-2014, 12:17 PM
Thumbs up Re: Going in for the kill, EGR!
Def. turbo drain and banjo bolts. also consider cleaning the turbo.
05 F250, 6Spd, 4" turbo back Magnaflow Duals, No cat. No muffler, Egr delete, Intake, SCT X4
bronco3512 is offline
