HELP!! HGs replaced won't start. Sound changed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 03-08-2014, 07:32 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
I've put everything back together on my truck. I primed it quite a bit. Cranked it a while. It fired and immediately died. Now when trying to start it sounds bogged down. Like it isn't cranking as fast. Tested battery's. 100% charged 12.8v. Can't get videos to upload from my phone
2005 F250 w 6.0 PSD
SCT X3 - Innovative Tunes, Edge Insight CTS, aFe Intake, 4" DP - 5" StraightPipe, Level Kit w 36" Toyo MTs, BPD Oil Cooler, BPD Water Pump, ARPs, freshened and updated turbo, 6.4 Banjos, Blue Spring, CCV Mod, Fumoto Valves (coolant plugs), Mobil DelVac 5w40, CAT EC-1
PSDcell is offline
post #2 of 19 (permalink) Old 03-08-2014, 07:36 PM
matthewd11's Avatar
Re: HELP!! HGs replaced won't start. Sound changed
Is there any smoke out the tail pipe cranking? make sure you connected all grounds. Did you load test the batteries or just check the voltage?
matthewd11 is offline
post #3 of 19 (permalink) Old 03-08-2014, 07:54 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
No smoke. It fired and died IMMEDIATELY. It sounds incredibly different now. I had the batteries tested at autozone. I believe their tester load tests?
2005 F250 w 6.0 PSD
PSDcell is offline
post #4 of 19 (permalink) Old 03-08-2014, 08:00 PM
matthewd11's Avatar
Is the cranking speed slower, or does the engine sound odd? Valve timing could be off. Did you install the rockers/pushrods by the book? Try to get that video uploaded. Did you happen to notice if any fluid levels have changed dramatically (coolant/oil)?
post #5 of 19 (permalink) Old 03-08-2014, 08:04 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
The actual cranking sounds odd. Like something is bogging down the starter. I'm going to upload the videos in the next hour or two
2005 F250 w 6.0 PSD
PSDcell is offline
post #6 of 19 (permalink) Old 03-08-2014, 08:29 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
I guess it could be timing? Compression doesn't sound right
2005 F250 w 6.0 PSD
PSDcell is offline
post #7 of 19 (permalink) Old 03-08-2014, 08:36 PM
matthewd11's Avatar
try turning the engine over by hand to see if it binds at all. First place i would look though IMO is valve timing. I know it will suck but if you cant figure it out, may have to remove valve covers and oil rails and turn engine over by hand and observe rocker movement.
post #8 of 19 (permalink) Old 03-08-2014, 09:51 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
Video of initial start
Video of next try
Still thinking timing? Cause I'm lost
2005 F250 w 6.0 PSD
PSDcell is offline
post #9 of 19 (permalink) Old 03-08-2014, 09:55 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
Just incase the first links don't work
initial try
Vid1 Video by PSDcell | Photobucket
Second try
Vid2 Video by PSDcell | Photobucket
2005 F250 w 6.0 PSD
PSDcell is offline
post #10 of 19 (permalink) Old 03-09-2014, 12:51 AM
matthewd11's Avatar
It sounded like you may have bent a pushrod(s). Heard a "snap" type noise as it fired and died. Definitely has no compression on some cylinders by the sound of it. Take the valve covers and oil rails back off and check to see what happened.
