Head gasket failure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 03-04-2014, 11:24 PM Thread Starter
Head gasket failure
We'll a few weeks ago my head gasket started to fail on my 06.. The funny thing is that my truck is studded running a street tune, with 175/stock injectors.. And stock turbo. I don't have 11000 miles on my truck and never really got worked hard since studded.. Could this of been a flaw in my mechanics work? Or what
250stroker06 is offline
post #2 of 32 (permalink) Old 03-04-2014, 11:28 PM
matthewd11's Avatar
Re: Head gasket failure
possibly. Were the heads checked/milled? Valve work? What did he do for block prep? Did you use OEM head gaskets?
matthewd11 is offline
post #3 of 32 (permalink) Old 03-04-2014, 11:41 PM Thread Starter
Used Oem gaskets, heads were inspected and milled.. And block prep. Not sure.
post #4 of 32 (permalink) Old 03-05-2014, 12:23 AM
IIvonnyII's Avatar
Did he get the heads magnafluxed for cracks ?
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #5 of 32 (permalink) Old 03-05-2014, 01:12 AM Thread Starter
Yes he did.. We'll he said I had no cracks. Not sure if he did that..
post #6 of 32 (permalink) Old 03-05-2014, 01:34 AM
Rob D's Avatar
What exactly is happening to lead you to believe you lost the HG already?
Special thanks to:
Doug @ GOGO Diesel
Ryan @ Full Force Diesel
Adam @ FCDP
Matt @ Gearhead
Rob D is offline
post #7 of 32 (permalink) Old 03-05-2014, 01:41 AM Thread Starter
I am getting so much back pressure that my over flow tank is empty and still pushing coolant out of my over flow cap wile driving under a load.. Like overdrive..
post #8 of 32 (permalink) Old 03-05-2014, 04:26 AM
IIvonnyII's Avatar
Get a new cap? Check the degas bottle for leaks ?
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
post #9 of 32 (permalink) Old 03-05-2014, 11:16 AM
Rob D's Avatar
I am not trying to ask annoying questions but sometimes guys looks past very simple issues. In other words lots of guys jump to a HG failure the second coolant is lost which may not be the cause of the lost coolant. Did you delete your EGR when you did studs?
Some guys interchange head stud and head bolt by accident - two very different things. You bought aftermarket studs and supplied them to your mechanic or was this done at a dealer who would have just put in head bolts?
Special thanks to:
Doug @ GOGO Diesel
Adam @ FCDP
Matt @ Gearhead
Rob D is offline
post #10 of 32 (permalink) Old 03-05-2014, 01:11 PM Thread Starter
I mean under boost coolant is coming out so bad from my cap that its dripping off my coil springs.. And it's only under boost cause you can hear it to. But yes we used arp head studs, Oem gaskets, and put an egr delete on.
