EGT sensor placement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-01-2014, 10:15 AM Thread Starter
Weatherlite's Avatar
Garage
I've read that the most accurate, and important, EGTs to monitor are between the manifolds and the turbo. Since I'll have the turbo off anyway, I figured I would go ahead and put it in there. Normally I would be afraid of leaving bits of metal in the pipe and risk them getting pushed into the turbo, but with the y-pipe off I can just vacuum them out.
What I need to know is if there is an optimum placement for the sensor. I would assume after the two pipes "y" into one, but how close to the turbo should it be?
Weatherlite is offline
post #2 of 13 (permalink) Old 03-01-2014, 11:36 AM
Banned
Re: EGT sensor placement
Driver side exhaust manifold just before it bends to go into the uppipe-ypipe
sent from my Smart Car
miller45103 is offline
post #3 of 13 (permalink) Old 03-05-2014, 03:47 AM Thread Starter
Garage
Ok, why there? I've been looking around and have seen recommendations for drivers side before the Y, passenger side before the Y, after the Y....but no one really seems to be able to articulate WHY each position is the best. I would think, educated guess really, that after the Y would be best as it measures a composite of both sides. If I put it on the passenger side but the drivers side is 200 degrees hotter, I will still only see the cooler temp. But, if I put it after the Y, at least I would see a rise in temp due to the hotter exhaust from one side mixing with the cooler exhaust from the other.
post #4 of 13 (permalink) Old 03-05-2014, 01:14 PM
Banned
Driver side is USUALLY the hottest and of course cylinder #8 has the hottest gases flowing beside it. Also, the gas can cool slightly before the y pipe. The temp isn't going to double when they mix. It will stay the same.
post #5 of 13 (permalink) Old 03-06-2014, 10:47 AM Thread Starter
Garage
I know it won't double, was just thinking that if left side was 700 degrees and right side was 600 degrees, after the Y would see 650 degrees....given equal volumes of exhaust gasses of course.
Why do you say #8 has the hottest gases flowing past it?
post #6 of 13 (permalink) Old 03-06-2014, 10:55 AM
Banned
Its the last on the bank.
post #7 of 13 (permalink) Old 03-06-2014, 11:00 AM Thread Starter
Garage
I would agree that it has more flow past it since 2, 4, 6 go past it, but hottest? By your reasoning wouldn't #7 also be hottest since it's last on it's bank? (ignoring the EGR of course) And if so, what would it matter if both sides therefore had the hottest gasses....they would be equal.
post #8 of 13 (permalink) Old 03-06-2014, 03:05 PM
Banned
Since you seem to know all about it, why did you ask?
Also, cylinder #8 is last to get coolant, so temps could be slightly higher.
post #9 of 13 (permalink) Old 03-07-2014, 09:41 AM Thread Starter
Garage
No need to be snide/sarcastic. I'm knowledgeable with gassers but relatively new to diesels, and so I'm trying to educate myself. I'm good with theory, but don't have the practical knowledge, which is why I asked. My comment was based on theory, but was wondering if I was missing something from the practical side of the coin....such as #8 getting coolant last. I don't imagine it would make a huge difference in exhaust temps on that cylinder, but it would definitely make a difference. That's the kind of stuff I'm looking for. Thank you.
post #10 of 13 (permalink) Old 03-07-2014, 10:39 AM
Intelligent Burro
The most accurate readings are closest to the manifold. If you are concerned a out one side hotter than the other, install 2 gauges. LH/RH.
E99, F250, 7.3, CCLWB, Auto, manual 4x4, AIS intake, AD injectors, PHP FU, AIC, 3:73 gears. Autometer Gauges - (EGT, Trans Temp, Boost), Edge CTS
Dieselpop is offline
