Totally New to 6.0 - Needs a Little Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-22-2014, 01:55 AM Thread Starter
I just (Finally) bought my first Super Duty - 2003 6.0 F250 King Ranch - I have wanted one FOREVER - Finally found a great deal !
Of course as soon as I did - Everyone told me that it will blow up any minute.. because it's the 6.0 - Whatever..
I am NOT a expert on Diesel Trucks - SO any advice is greatly appreciated -
Assume I am totally Green on the Subject ( I really am )
I am considering a Tuner to help Monitor and Help with Fuel Economy -( 1st Tank was 14.5 MPG) I will also be towing a 26' Pontoon Boat this summer - so a good tow set up is also needed. A friend Suggested a Edge Programmer since he has one on his Gas truck - I won't be racing the truck or going crazy.. (The Shelby keeps that market cornered) .. But I would like a good tuner to handle the items listed above..
As Stated I have a 03 F250 6.0 King Ranch with 72K miles -35's on the truck - And a additional Pillar mounted Inst Cluster for Boost and Fuel Pressure (Exh Temp doesn't seem to be hooked up) Someone also deleted the Cat
Otherwise -
I have no idea if anything else was done internally to the motor (Bulletproofing?) or anything else... Anyone have a easy way to tell?
Thanks in Advance for Any Help - Suggestions you can provide
Carolina-2003-6.0 is offline
post #2 of 10 (permalink) Old 02-22-2014, 02:02 AM
Wyo
scouts out...
Wyo's Avatar
Re: Totally New to 6.0 - Needs a Little Help
As far as tuners for a 6.0l I would go with SCT livewire. Basically a tuner and monitor, I am very happy with it and it seems to be the most referred programmer on this and many other sites.
2007 CC, Lariat, 6.0L, TreadWright guard dogs, straight piped out the back, egr delete, blue spring, 6.4 banjo bolts, high idle mod(bcp), bulletproofed, SCT Livewire TS with Drews street runner(under development for high elevation), Innovative, and Vivian's tunes, ww2.
Wyo is offline
post #3 of 10 (permalink) Old 02-22-2014, 02:06 AM
2Dstorm's Avatar
Sct tuners are the only way to go on these trucks!
Drews custom tunes back road performance
4/5" exhaust
Coolant filter
Use only ford filters (fuel and oil)
5w40 t6 oil
Save up 3k and wait for the problems to start
Egr/oil cooler, head gasket/studs are your weak points I wouldn't mess with it until you start having problem. You will know!! Lol
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #4 of 10 (permalink) Old 02-24-2014, 12:36 AM
spoiled450boy's Avatar
1996 F-250 5 speed 96,000 original miles. Baby swamp injectors, custom tuned ts 6 position chip, napa 6637 filter, straight piped and bigger clutch.
2003 F-250 6.0 6 speed, 450 hp southbend clutch, egr delete, AFE intake and SCT programmer.
spoiled450boy is offline
post #5 of 10 (permalink) Old 02-25-2014, 02:41 AM
Welcome to the world of 6.0. As stated above SCT is the only way to go for a tuner. For monitoring you have a lot of options I use an edge cs with egt add on probe. Regular maintenance with Ford filters and you should have years of use as long as you don't hot rod it. Enjoy your truck.
09 SCREW 4X4
acplowboy84 is offline
post #6 of 10 (permalink) Old 02-25-2014, 10:54 AM
Swamp trash...
Merc82's Avatar
Great advice, make sure you monitor it before tuning.
Chris. 06 LBCC XL 4◊4
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #7 of 10 (permalink) Old 02-25-2014, 11:46 PM
Scangauge2 is great basic monitor for the budget minded. Key is your coolant versus oil temps. This will give you some idea of how your engine is running. Just my routine for used vehicles - fresh oil with fileter (motorcraft) and fuelsfilters (motorcraft) which was mentioned previously.
- Will
2006 F350 CC SB / 130k to 207k - "SOLD"
2017 F350 CC LB / All OEM / Nitto Terra Grappler G2s
SDER1 is offline
post #8 of 10 (permalink) Old 03-03-2014, 01:01 AM
there is no way to tell if your truck has been studded. i would invest in a coolant filter system. worth every penny. sct only for tuner. the livewire ts is a nice unit.
06leaker is offline
post #9 of 10 (permalink) Old 03-03-2014, 04:27 PM
IIvonnyII's Avatar
Yes there is a way to see if your truck is studded or not. Just look at the heads and look for headbolts or headstuds .
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #10 of 10 (permalink) Old 03-05-2014, 05:48 AM
kellyrulzz's Avatar
2005 F-350 XLT SRW 4X4
EGR Delete
Banks Monster CAT Back
SCT SF3
Stock Headbolts
Looney by Eric from Quick Tricks Auto!
Street King by Drew.
kellyrulzz is offline
