Icp sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-21-2014, 04:15 PM Thread Starter
cope102's Avatar
Icp sensor
We're is icp located on 2004 6.0? How hard is it to change?
2004 F350 DRW FX4 Banks Six Gun Tuner,Egr delete, Adrenaline pump, Banks air, 4 inch straight pipe exhaust
cope102 is offline
post #2 of 8 (permalink) Old 02-21-2014, 04:26 PM
JGman141
Jgman141's Avatar
Re: Icp sensor
2003-2004 it's behind the turbo, 2004.5 and up its on the passenger side valve cover.
Jgman141 is offline
post #3 of 8 (permalink) Old 02-21-2014, 04:32 PM Thread Starter
cope102's Avatar
Re: Icp sensor
I was told I might have bad icp sensor.. I'm not afraid pulling it but don't even know what it looks like...
cope102 is offline
post #4 of 8 (permalink) Old 02-22-2014, 11:00 PM
blitzin247's Avatar
Re: Icp sensor
go to the 6.0 bible on this site, it will point it out to you.
1994.5 XLT ECLB Reman factory injectors, Rebuilt ZF5, LUK Clutch and single flywheel conversion. STOCK and looking to change!
Totaled 7/24/14 600hp 04 LB7 CCSB with some goodies
Jesus loves YOU, have you asked Him to be your savior yet?
blitzin247 is offline
post #5 of 8 (permalink) Old 02-22-2014, 11:03 PM
whistle tits
ghohouston's Avatar
Re: Icp sensor
Look on the passenger side valve cover, towards front of the engine, is there a sensor with a 3 wire harness going to it?
ghohouston is offline
post #6 of 8 (permalink) Old 03-04-2014, 03:46 AM Thread Starter
cope102's Avatar
Re: Icp sensor
yup right there on the valve cover.. is there a way to test voltage on it?
cope102 is offline
post #7 of 8 (permalink) Old 03-04-2014, 05:54 PM
Re: Icp sensor
I look at IPR command, if its at 15% the sensor is probably bad. What are the symptoms? If a no start you can unplug it, if the motor then starts replace the sensor. Monitoring, like the CTS, Dashboss etc. makes things much, much easier.
jrainw is offline
post #8 of 8 (permalink) Old 03-05-2014, 02:09 AM Thread Starter
cope102's Avatar
Re: Icp sensor
idling like its missing and threw code for bad icp sensor.. already ordered a new sensor just waiting for it to come in mail... is there a particular kind socket to pull sensor loose?
cope102 is offline
