Quick injector question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-09-2014, 03:14 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
Is it necessary to teardown a stock injector to replace the O-rings or is it ok to "roll" the new ones on? I need to re- install them today and after reading on some of the other o-rings (stand pipes) I'm wanting to make sure sliding them over the injector won't stretch out the rings
2005 F250 w 6.0 PSD
SCT X3 - Innovative Tunes, Edge Insight CTS, aFe Intake, 4" DP - 5" StraightPipe, Level Kit w 36" Toyo MTs, BPD Oil Cooler, BPD Water Pump, ARPs, freshened and updated turbo, 6.4 Banjos, Blue Spring, CCV Mod, Fumoto Valves (coolant plugs), Mobil DelVac 5w40, CAT EC-1
PSDcell is offline
post #2 of 5 (permalink) Old 02-09-2014, 03:28 PM
Banned
Re: Quick injector question
Just lube them up with grease and you will be fine. Make sure you dont put any in the solenoid opening on top though.
The nice thing about grease is that it holds up better then oil, but diesel can also cut through it.
Sent from my Smart Car
miller45103 is offline
post #3 of 5 (permalink) Old 02-09-2014, 03:57 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
Sorry just wanna make sure I get it right. You're saying it's ok to slide the new orings I without disassembly as long as I grease the orings first? Should I use assembly lube to grease them?
2005 F250 w 6.0 PSD
PSDcell is offline
post #4 of 5 (permalink) Old 02-09-2014, 04:04 PM
Banned
Yep.
Taking the injector apart won't help anyways.
You can use any type of grease as long as its clean. Putting the oring on the injector isn't the problem. Its when you slide the injector into the cup/head. That's when you risk gouging the oring the most. All you are doing is making sure it can slide smoothly.
post #5 of 5 (permalink) Old 02-09-2014, 04:07 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
Ok. Thanks bud. Heads going back in tonite!
2005 F250 w 6.0 PSD
PSDcell is offline
