Best fuel system? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 02-07-2014, 06:52 PM Thread Starter
2Dstorm's Avatar
Question Best fuel system?
So my new injectors are on the way (Warren 175/75 with spool upgrade) Jess thinks the stock system is sufficient. Patrick said I should do a fuel system. What's should I so? I have a regulated return already. So here's my question if I decide to go with a fuel system what's the best option for me, it's a dd that tows three to five times a year. Thanks in advance for any helpful info.
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #2 of 18 (permalink) Old 02-07-2014, 06:56 PM
JGman141
Jgman141's Avatar
Re: Best fuel system?
Airdog 150 feeding your stock pump, that should be more than enough to keep up with that size of injector.
Jgman141 is offline
post #3 of 18 (permalink) Old 02-07-2014, 07:04 PM Thread Starter
2Dstorm's Avatar
I have seen a lot if trash talk about the airdog products makes me scared to buy one
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #4 of 18 (permalink) Old 02-07-2014, 07:53 PM
JGman141
Jgman141's Avatar
It's only the airdog 2 that sucks, I had one and it went out 3 or 4 times. The pump was originally designed for low pressure applications like the cummins and dmax use. The 6.0 needs around 50-60psi of fuel, the only difference I could find between the airdog 150 and airdog 2 was the regulator. When you have a system designed to function as a low pressure pump and jam a stiffer regulator in to get it up to the required pressure, things are going to go bad . I know Nate (windrunner408) has ran a airdog 150 for over 2 years now with zero issues. So a stock pump with an ad 150 pump acting as a lift for it should have no issues feeding 175/75 injectors( as long as the stock pump is healthy). Hope this helps
Jgman141 is offline
post #5 of 18 (permalink) Old 02-07-2014, 08:27 PM Thread Starter
2Dstorm's Avatar
Called sinister doing an airdog 150 and sinister sump $715 is that a good deal?
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #6 of 18 (permalink) Old 02-07-2014, 08:51 PM
JGman141
Jgman141's Avatar
Sounds about right to me
Jgman141 is offline
post #7 of 18 (permalink) Old 02-07-2014, 08:53 PM Thread Starter
2Dstorm's Avatar
On the way
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #8 of 18 (permalink) Old 02-19-2014, 10:20 AM
I'm running Full Force 190/100s with a RR and stock fuel pump... no sump no feeder pump... 62-63 psi all day long...
Dan / Dando
04 F-250 CCSB, she's got stuff...
DieselShopCT.com
GatorBaitR6 is offline
post #9 of 18 (permalink) Old 02-20-2014, 02:15 AM Thread Starter
2Dstorm's Avatar
Did I waste my money? Every vendor I talked to told me to get the pump
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #10 of 18 (permalink) Old 02-20-2014, 02:27 AM
JGman141
Jgman141's Avatar
No you didn't waste your money, your taking a lot of strain off of your stock pump and if you decide to step up to a fuel lab or a1000, you'll have a nice lift pump to supply that as well.
Jgman141 is offline
