Another 6.0 Headgasket thread, Questions from a newbie - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 02-06-2014, 01:33 AM Thread Starter
So i'm going to be ordering all the stuff I need for my headgasket job on my 04 Excursion 6.0
My lack of organizing skills and my ADD get the best of me. So please don't mind if I ask the same question that 100 other people have at random.
Where are the best places to find all of this stuff? I have a local dealer ship that i can get the factory stuff for 20% off. and the rest i plan on buying online but don't know whom to go with.
I need
Headgasket kit
T-Stat and gasket
Serp belt
Glow plug harness Both sides
DC alternator
ARP studs
Injectors (I'm not sure if i shouldn't just wait on this step)
Turbo (Same, Internal damage minimum, but various chunks missing from the fins and mild pitting on the unison rings and vanes working fine for now, but will this cause an issue under normal driving conditions?)
I have the Bulletproof oilcooler setup and the EGR cooler ( Will buying the delete screw with WA emissions / Will it benefit me to delete the EGR valve ?)
What gaskets are not commonly supplied with the headgasket kit?
Cat ELC-1 coolant
I'm on a "Budget", a budget of a 6.0 owner... I want to do it right, but not go overboard with things until it's needed.
Do i wait on the injectors and turbo until later?
thanks!
Nick
Tweaker727 is offline
post #2 of 15 (permalink) Old 02-06-2014, 01:40 AM
The Muscle Hamster
PSDcell's Avatar
Re: Another 6.0 Headgasket thread, Questions from a newbie
Doing the head gasket job on my own. If you're looking for a ball park number, I'm done buying parts, fluids, and the odds&ends for $2500.
Head gaskets from ford come in a kit that does only one side. The kit has the gasket, head bolts, and mine came with the oil stand pipe.
2005 F250 w 6.0 PSD
SCT X3 - Innovative Tunes, Edge Insight CTS, aFe Intake, 4" DP - 5" StraightPipe, Level Kit w 36" Toyo MTs, BPD Oil Cooler, BPD Water Pump, ARPs, freshened and updated turbo, 6.4 Banjos, Blue Spring, CCV Mod, Fumoto Valves (coolant plugs), Mobil DelVac 5w40, CAT EC-1
PSDcell is offline
post #3 of 15 (permalink) Old 02-06-2014, 08:16 AM
Banned
I need
Headgasket kit
T-Stat and gasket
Serp belt
DC alternator
ARP studs
Cat ELC-1 coolant
thanks!
Nick
Really if ur wanting to do anything to the truck do it while u have everything apart. Hate to put it all back together and then have to take it apart again..
The turbo if ur missing chunks Id definitely do something with it.
Id add the 6.4 banjo bolts.
quadracer711 is offline
post #4 of 15 (permalink) Old 02-06-2014, 10:35 AM
Strokin Roughneck
txdieselmech84's Avatar
Send a message via Yahoo to txdieselmech84
I would stay away from 6.4 banjo bolts a ford tech told me they could cause injector failure.
txdieselmech84 is offline
post #5 of 15 (permalink) Old 02-06-2014, 11:14 AM
The Muscle Hamster
PSDcell's Avatar
Did he explain? I don't doubt someone told you that, but it doesn't make sense to me and would like to know his reasoning
2005 F250 w 6.0 PSD
PSDcell is offline
post #6 of 15 (permalink) Old 02-06-2014, 11:24 AM
"Slap hands slap hands"
FlossyB's Avatar
I completely disagree with that how could putting the 6.4 banjo bolts which will increase fuel flow especially at WOT cause injector failure. It actually if anything is a preventative and does the exact opposite potentially lengthening the life of the injectors by making sure they are getting the proper amount of fuel. I did extensive research on this as well as asked my diesel mechanic who worked at Ford on diesels for 13+ years specifically the 6.0s for the majority of this and he reccomend I get them as well as has them on his truck. I have never seen a thread or issue with anyone saying 6.4 banjo bolts lead to failing injectors. Just my .02 cents.
JB
FlossyB is offline
post #7 of 15 (permalink) Old 02-06-2014, 11:45 AM
Ford head gaskets are good. We use them plus installing ARP headstuds. Like stated you only get one in a kit, so you will need two kits. If interested, I have two victor reinz kits here that I will send you one for the shipping. They are the 18mm dowels. If you get a discount at Ford, then use the injector harnesses, and thermostats, and what ever other parts you can get. If doing injectors, get Alliant Power or Industrial Injection ones. Those are what we use here at the shop. If doing a turbo upgrade, the Powermax is a great option. They work well and spool nice. If using the same one, try installing a new compressor wheel and cleaning the unison ring. I think you will be happier with using a Powermax turbo. You are spending a few $$ anyway, do the job right. Buy once, cry once. Not sure what your emissions law are but I would delete the EGR cooler and valve if possible.
simmy952 is offline
post #8 of 15 (permalink) Old 02-06-2014, 05:56 PM
Banned
Or go to jesse warren at warren diesel for injectors
post #9 of 15 (permalink) Old 02-06-2014, 06:49 PM Thread Starter
I've heard alot of good things about Warren injectors, Like wise with MTW turbo.
while i'm trying to replace any thing that needs to be, I don't feel like spending the most money on each option.
I already have an SCT tuner, (Which is were i think my problem started for me)
Thanks everyone for the heads up on the head gaskets one per box.
post #10 of 15 (permalink) Old 02-06-2014, 11:08 PM
so ive got 2 head gasket kits from international I bought,didnt know you get head gaskets when you buy ford reman heads,ill look up what I paid and make you a deal,im in Woodinville,no frieght
1996 cclb,3inch rsk,diy air cleaner,diy tugger kit,3 inch dp,4.10s,kmc 20s--gone and I miss her
2004 ccsb,6 inch lift ,37 toyos,sinister egr delete,arp studs,ARB bull bumper,oem heads with oem gaskets,atlas 80 and premium ficm from ficmrepair.sctx2 innovative tunes,pioneer app radio 3
wa96stroke is offline
