head studs cab on or pull motor? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 02-05-2014, 01:34 AM Thread Starter
Strokin Roughneck
txdieselmech84's Avatar
Send a message via Yahoo to txdieselmech84
I am going to be doing head studs, egr delete p-max turbo and hopfully injectors. I am looking to make a solid 500hp. Just how much of a pain in the ass are the heads to do in-frame? What other upgrades should I be looking at doing while the engine is apart? Does anyone have a step by step on a head job? Any advice is more than welcomed. Prices on parts, recommendations, ect.
txdieselmech84 is offline
post #2 of 37 (permalink) Old 02-05-2014, 01:39 AM
$3800.06Fx4's Avatar
Re: head studs cab on or pull motor?
It's not hard to do in chassis. You can do studs without pulling the cab or engine. You just have to pull out the heater box.
2006 CCSB
ARP's 4"
MBRP STRAIGHT PIPE
EGR DELETE
SCT 3015 ID
PORTED INTAKE
MBRP INTAKE ELBOW AND CAC PIPES
COOLANT FILTER
1995 BRONCO 351W 4WD
1997 CCSB 7.3PSD 4WD CURRENTLY STOCK, WITH BUILT TRANSMISSION.
1991 CCLB DUALLY 7.3 IDI
$3800.06Fx4 is offline
post #3 of 37 (permalink) Old 02-05-2014, 01:41 AM
Never pulled the cab or motor to do studs on a 6.0l I do a couple sets a month in our shop.
Mr. Navistar is offline
post #4 of 37 (permalink) Old 02-05-2014, 02:29 AM
Banned
Ive done a dozen or so.
People may have there ways of doing it but pulling the cab is definitely the easyest.
I no a bunch will agree.
quadracer711 is offline
post #5 of 37 (permalink) Old 02-05-2014, 08:06 AM
What year is the truck? If its 05-07 then you would want to do the stc fitting and the stand pipes and dummy plugs if they haven't been done. I would install some sort of regulated return if you plan on injectors.
How many miles does the truck have? A coolant flush and rebuilding the oil cooler might be a good idea, then running elc coolant and a coolant filter for reliability.
Triumph1188 is offline
post #6 of 37 (permalink) Old 02-05-2014, 10:33 AM
Banned
Id lift the cab.
Plus you can pressure wash everything easier.
Sent from my Smart Car
miller45103 is offline
post #7 of 37 (permalink) Old 02-05-2014, 06:24 PM
The Muscle Hamster
PSDcell's Avatar
I did a lot of research on mine before I started. Started a build thread.my full parts list is on the first page. Parts, fluids, specialty tools and everything else, I'm currently at ~$2500
6.0 - Headgaskets, updates, odds and ends (with pics) - PowerStrokeNation : Ford Powerstroke Diesel Forum
2005 F250 w 6.0 PSD
SCT X3 - Innovative Tunes, Edge Insight CTS, aFe Intake, 4" DP - 5" StraightPipe, Level Kit w 36" Toyo MTs, BPD Oil Cooler, BPD Water Pump, ARPs, freshened and updated turbo, 6.4 Banjos, Blue Spring, CCV Mod, Fumoto Valves (coolant plugs), Mobil DelVac 5w40, CAT EC-1
PSDcell is offline
post #8 of 37 (permalink) Old 02-05-2014, 07:50 PM
D66stroke
D66stroke's Avatar
We just did mine cab on, it's just time consuming really. I'd say the heater box is the only PITA about the whole job, and torquing is kinda hard since it's hard to get leverage when leaning over the truck
97 F-250, 300/100's, e-fuel, Gearhead tunes, Stokers Unlimited stage 3 trans and T4 mount, s366, ARP studs, Comp 910's, Smith Bros PR's
09 Cadillac CTS-V, long tubes/Xpipe, Jeremy Formato tuned, ID850's, 2.38 upper pulley, NorCal icebox, Hennessy heat exchanger
D66stroke is offline
post #9 of 37 (permalink) Old 02-05-2014, 09:09 PM Thread Starter
Strokin Roughneck
What upgrades does anyone recommend? it is an 07 dont know if that helps
post #10 of 37 (permalink) Old 02-05-2014, 09:13 PM
Banned
STC fitting
