Front end sits higher then rear after lvling kit install. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-02-2014, 06:34 PM Thread Starter
Hi people asking for info on what size blocks I need to make my 04 f250 (CC,SB) Fx4 sit level or just a bit taller in the rear. I put a zone lvling kit with the track bar on the front to lvl the truck out, now it sits like I have a load in the bed. Would the f350 blocks fix this and if so do I need a driveshaft shim or should I just order a block kit?
SCT- custom tunes
MBRP- 4'' Exhaust
S&B- cold air intake
Sinister- coolant filteration
hybridhoosier is offline
post #2 of 8 (permalink) Old 02-02-2014, 07:16 PM
"Slap hands slap hands"
FlossyB's Avatar
Re: Front end sits higher then rear after lvling kit install.
I'm not sure on the blocks sorry but my excursion did the same thing. I went with the ride rite air bags they are phenomenal. Better ride quality with and without towing. Also easily adjusted when you put a load on so the truck stays level and keeps that great ride quality. I reccomend going that route.
JB
FlossyB is offline
post #3 of 8 (permalink) Old 02-03-2014, 12:03 AM
PursuitInterceptor
HeavyAssault's Avatar
About how far off is it from level??
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #4 of 8 (permalink) Old 02-03-2014, 04:18 AM
my lift has progressive rate front coils but just a set of blocks in the rear (SRW F350) the front does a great job of soaking up the road but the rear just skims along unless im loaded or pulling a trailer. could I remove the rear blocks and a rear spring or two and sub in the air bags to improve the ride quality while retaining the ride height and towing ability?
I think the answer is yes but want to confirm.
Deadringer is offline
post #5 of 8 (permalink) Old 02-03-2014, 07:28 PM
F-350 Blocks leveled mine out perfect with the 2" "Level" blocks in the front.
Check the classifieds or Craigslist or just go to the Stealership....
D
2005 CC SB 147K
MTW MaDmAx 66mm VGT
Warren Diesel 175/75's & Jess' Race Tune
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 6.5"
Mickey T's ATZ P3 37's
METHOD Racing Wheels 20x
SG II
Bltprf EGR Del. & Ext. Filter
ELC & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
DLinzy is offline
post #6 of 8 (permalink) Old 02-05-2014, 03:53 AM
Anyone?
post #7 of 8 (permalink) Old 02-06-2014, 06:22 PM
I have my f350 blocks if interested let me know
BigRig is offline
post #8 of 8 (permalink) Old 02-06-2014, 10:40 PM
FlossyB's Avatar
Anyone?
I don't see why this wouldn't work and help your towing and ride I would double check with a shop first just to be safe though.
JB
FlossyB is offline
