Unplug egr? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-29-2014, 11:00 PM Thread Starter
Dieselnut7.3's Avatar
Unplug egr?
Hello everyone...I've been doing some research and I can't decide if I should unplug my egr valve...I can't do a delete cause I have a warranty on my truck but I've heard that unplugging it can make it run better and better mpg....but I've also heard that it can cause some issues...any advise
Is appreciated...thanks
2003 F-250 6.0L 102kmi all stock except 4in cat back exhaust
(sold)1995 F-350 Dually 5sp 310k and counting. cold air intake, ts 6 position chip, Stage 1 injectors, 3in DP to 5in dual stacks.,
Dieselnut7.3 is offline
post #2 of 7 (permalink) Old 01-30-2014, 11:21 PM
Swamp trash...
Merc82's Avatar
Re: Unplug egr?
On some strategies I have been told that unplugging the egr valve affects fan operation.
Chris. 06 LBCC XL 4◊4
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #3 of 7 (permalink) Old 01-30-2014, 11:23 PM Thread Starter
Re: Unplug egr?
I have the most current flash on my ECM it was done by the dealer I bought it from....and I've read that too...but with the temps up here now I don't think I have to worry about that right now lol
post #4 of 7 (permalink) Old 01-31-2014, 10:24 PM
Re: Unplug egr?
You will get at minimum a CEL on the dash. I can't say if it will affect performance or anything else, I do not know.
With a tuner you can disable the EGR, so the valve is still connected but never opens. The tuner can also turn off the dash light. You'd have to check and see if the tuner (SF3/X3) will void the warrantee.
You are in a not so ideal spot. The EGR system is best to delete/bypass for the longevity of your engine. It's a shame that you must keep it.
6.0van is offline
post #5 of 7 (permalink) Old 01-31-2014, 10:46 PM Thread Starter
Re: Unplug egr?
The wierd part is that my cel doesn't come on...and I'm hesitant about getting a programmer because it's stock and I don't want to f anything up...and trust me i wish I could get rid if it
post #6 of 7 (permalink) Old 01-31-2014, 11:21 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: Unplug egr?
2003-2004 generally will not throw a CEL or code.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #7 of 7 (permalink) Old 02-01-2014, 01:30 AM
Re: Unplug egr?
I sure am glad there is no internet cop waiting to send out tickets every time someone (me) posts incorrect information.
It sounds like you are in decent shape then. The exhaust can still roast the coolant, and the cooler could potentially leak eventually, but worst case scenario, the coolant would go out the back end rather than back into the intake.
6.0van is offline
