Edge CTS help please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-26-2014, 02:41 AM Thread Starter
I just got an Edge CTS installed about a week ago. I cant figure out how to get the PIDs I want on there. According to Edges website, I should have these available options:
Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed (03-04), Engine Coolant Temp, Engine Load, Engine Oil Temp, Engine RPM, Engine Run Time, Exh. Backpressure, FICM Voltage, FICM Synchronization, Gear with TCL, ICP Pressure, ICP Voltage, INJ Press Regulator, Injector Pulse Width, Intake Air Temp, Main INJ PWR, Manifold Abs Pressure, Mass Air Flow, Mileage Coach, MPG Instant, MPG Average, TCC Duty Cycle, Time 0-60, Time 1/4 mile, Trans Fluid Temp, Turbo Boost, Vehicle Speed (04-07), Variable Geometry Turbo Duty Cycle
I don't see hardly any of those options to select from? I have it plugged in, and the EGT probe (added) works, I have coolant temp, and MAP PSI (which is annoying because I have to subtract 12 from whatever it reads I have for 'boost"
How do I get these vehicle specific PIDs on here? I know how to search and change PIDs, I just dont have most of these options.
2004 F350 SRW Longbed Lariat. 4x4 w/ 3.73 LS. SCT Tuner w/ Innovative Diesel XtremeX Tune. ARP Headstuds, Sinister Diesel Coolant Filter, "Blue Spring" Fuel Pressure Upgrade
Colo6.0 is offline
post #2 of 4 (permalink) Old 01-26-2014, 04:03 PM
Re: Edge CTS help please
First things first, I'd hook it up to your computer and check for updates. Who set it up for you? Make sure the unit knows your vehicle information. If you unplug it from the obdii port (vehicle power off) and plug it back in, then apply power, it should confirm vehicles info including VIN.
2004 Excursion
birdmayon is offline
post #3 of 4 (permalink) Old 01-26-2014, 04:08 PM
dsberman94's Avatar
I would also hook it up to the computer to check for updates. Almost guaranteed that's where your problem lies.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #4 of 4 (permalink) Old 01-26-2014, 10:32 PM Thread Starter
Ok will do, thx guys! Shop that did it I think just installed it w/o configuring it with a computer. I'll start there. Thank you!
Colo6.0 is offline
