Clean block for head gaskets? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 01-25-2014, 04:51 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
So, I'm halfway through my HG/updates project. Should be getting the heads back Monday-ish
6.0 - Headgaskets, updates, odds and ends (with pics) - PowerStrokeNation : Ford Powerstroke Diesel Forum
To those who have done this, what did you use to clean the HG residue off the block?
2005 F250 w 6.0 PSD
SCT X3 - Innovative Tunes, Edge Insight CTS, aFe Intake, 4" DP - 5" StraightPipe, Level Kit w 36" Toyo MTs, BPD Oil Cooler, BPD Water Pump, ARPs, freshened and updated turbo, 6.4 Banjos, Blue Spring, CCV Mod, Fumoto Valves (coolant plugs), Mobil DelVac 5w40, CAT EC-1
PSDcell is offline
post #2 of 19 (permalink) Old 01-25-2014, 07:47 PM
matthewd11's Avatar
Re: Clean block for head gaskets?
I would use the green scotch brite 2" disc. Not abrasive and will remove all residue. Brake/carb clean where needed, as well as a paint scraper.
matthewd11 is offline
post #3 of 19 (permalink) Old 01-25-2014, 11:29 PM
whistle tits
ghohouston's Avatar
Personally, I will ONLY use razor blades and brake cleaner on the block
ghohouston is offline
post #4 of 19 (permalink) Old 01-26-2014, 12:34 AM
09 6.4
webb06's Avatar
razor blades, wd40, 220 grit sandpaper. thats what i use everytime
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #5 of 19 (permalink) Old 01-26-2014, 12:48 AM
ford_trck's Avatar
Do this with a 2x4 for the sandpaper and go across the bores in an x pattern until you don't see high spots.
Early 99 F-350 CC LB 6-speed
Turbo, injectors, fuel, clutch, nothing special
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
Originally Posted by HeWhoIs View Post
The only brutha you know is the one that's bangin your little sister you cracka.
ford_trck is offline
post #6 of 19 (permalink) Old 01-27-2014, 07:05 PM Thread Starter
The Muscle Hamster
PSDcell's Avatar
Thanks guys! I've got a big paint scraper (razorblade) that should work.
Another question, I am looking at adding more wrapping my wiring harnesses (main harness and injector harness). Both will see a lot of heat. I will be wrapping over the factory wrapping. Would regular electric tape hold up to the heat?
2005 F250 w 6.0 PSD
PSDcell is offline
post #7 of 19 (permalink) Old 01-27-2014, 10:24 PM
matthewd11's Avatar
yes the tape will work fine.
post #8 of 19 (permalink) Old 01-27-2014, 10:28 PM
dsberman94's Avatar
Doesn't ford have some sort of super gasket remover. When ford does HGs unless they are really bad like a 6.0 that has been driven on blown HGs for a while they use green scotch brite type pads on an air tool and a razor blade. Not even brake cleaner. Brake clean on the heads themselves to clean them up
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #9 of 19 (permalink) Old 01-28-2014, 12:41 PM
On the most stubborn gaskets I have used a gel type paint remover.
lenzhotrod is offline
post #10 of 19 (permalink) Old 01-29-2014, 02:29 PM
Use the Scotch 88 series electrical tape, most don't even know it exists, but it is chemical and heat resistant.
http://www.mscdirect.com/product/786...&026=-99&025=c
D
2005 CC SB 147K
MTW MaDmAx 66mm VGT
Warren Diesel 175/75's & Jess' Race Tune
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 6.5"
Mickey T's ATZ P3 37's
METHOD Racing Wheels 20x
SG II
Bltprf EGR Del. & Ext. Filter
ELC & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
DLinzy is offline
