after market fuel line - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-25-2012, 10:40 PM Thread Starter
hey fellas im goin to be doin my fuel system and i was wondering where the best place to get the fuel line and adapterrs is thank you all for info
what a mess is offline
post #2 of 5 (permalink) Old 07-25-2012, 10:47 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: after market fuel line
I recommend getting them from Summit Racing and using Aeroquip fittings as much as you can.
Nate
windrunner408 is offline
post #3 of 5 (permalink) Old 07-25-2012, 11:52 PM Thread Starter
you have a link for the correct line and fittings? sir thank you much
post #4 of 5 (permalink) Old 07-27-2012, 07:17 PM Thread Starter
alright 3/8 or 1/2 hose??? what shoudl i run
post #5 of 5 (permalink) Old 07-28-2012, 02:44 AM
You should run 5/8in (10AN) from the tank to the suction of the pump and either 3/8in or 1/2in line from the pump discharge to the motor. Both have been proven to work. If you are running two pumps (a high and low pressure pump) use 10AN between the low pressure pump discharge and the high pressure pump's suction.
Nate
