5R110 Trans line pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 07-24-2012, 04:58 AM Thread Starter
Hey guys trying to figure out what line pressure runs in the Trans lines any input is helpful. Trying to get this truck going
DC Smoke, sct, eric-innovative, Hallas Performance, FCDP, Bullseye performance, Warren Diesel, Air Dog
04 ccsb black
egt, boost, fuel, air
205-100%
batmowheel
airdog II
coolant filter
stock trans until it explodes
ARP
Black Onyx
ďMy liver is like a diesel, takes awhile to get warmed up but after that she will run all night.ď
04smokeman is offline
post #2 of 2 (permalink) Old 07-24-2012, 02:01 PM
'05 Excursion
Term3's Avatar
If you put a pressure sensor in the place of the plug on the drivers side of the transmission just above the oil pan you will be able to see the pump discharge pressure. I believe it can go as high as 200 psi but I don't know for sure. The pressure in the lines going to the cooler is much, much lower though.
Sent from my Autoguide iPad app
Term3 is offline
