stock down pipe removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-14-2012, 10:53 PM Thread Starter
needing some suggestions on how to get the stock down pipe out,i cut the pipe behind the transmission cross member but am having a hell of a time getting it out, truck has a manual trans, any suggestions would be greatly appreciated
thephenom60 is offline
post #2 of 8 (permalink) Old 07-14-2012, 11:31 PM
06-6.0 stoker's Avatar
If your not worried about it cut it up till you get it out
Sent from my Autoguide iPhone app
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #3 of 8 (permalink) Old 07-15-2012, 01:20 AM
07_powerstroke's Avatar
Re: stock down pipe removal
Sawzaw and cut up as far as you can and in front of the cross member.
07 ford f250
Josh Vandyke
07_powerstroke is offline
post #4 of 8 (permalink) Old 07-15-2012, 07:36 PM
Pull the turbo and up pipes gives you a lot of room. As also said cut it in front of the trans crossmember.
onefaststang is offline
post #5 of 8 (permalink) Old 07-15-2012, 09:54 PM
Diesel Sled Head
zx800x's Avatar
I just drop the crossmember and weasel it out.
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
zx800x is offline
post #6 of 8 (permalink) Old 07-16-2012, 02:18 AM
BRING DA AMBALAMPS
stroke of luck's Avatar
why did you cut it? just pull the turbo and loosen the manifold bolts and pull it all out....
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #7 of 8 (permalink) Old 07-16-2012, 05:43 PM
Ian123's Avatar
You guys have to be joking about removing the turbo. With 2 people you can have the down pipe out in 2 or 3 minutes
2007 F-250 CCLB Lariat FX4 6.0L
Originally Posted by fuekear View Post
I just blow my heads off the block once a year. Keeps nice clean antifreeze in it, although not that cost effective it sure is fun.
Ian123 is offline
post #8 of 8 (permalink) Old 07-18-2012, 03:50 AM
BRING DA AMBALAMPS
doh!! I was thinking of the uppipe when he said downpipe. I just did mine a couple weeks ago so its still on the brain. advice fail.
