after market trany coolers????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-13-2012, 12:40 AM Thread Starter
6.0stroken's Avatar
list what ya got and how it works for you along with how much it cost you.
im in the works of getting on because my trans runs 180 when all warmed up with out ulling a load. i would like to see my temps down in the 120 to be honest. but i dont know if thats possible. ill be getting a deeper pan too. list thoes as well please.
04 f-250 quad cabin 4x4 auto 5r110, 190cc 100%, upgraded oil cooler, upgraded fuel spring regulator, 6.4 banjos, airdogII, gogo's direct clutch solenoid, 5'' exhaust with no cat, sct 3015 with xrace,xstreet,looney wild,srl+,ddp,rcd,super panty dropper, arp headstuds, sinister coolant filtration, sinister egr delete, moderate tuned 58v ficm.
6.0stroken is offline
post #2 of 11 (permalink) Old 07-13-2012, 12:54 AM
Poh
Respect my awesomeness
Poh's Avatar
Re: after market trany coolers?????
120 is too low
I have a tru cool max and I showed a steady 165 today pulling 16K @ 65 mph on flat ground. it goes up to 180ish in stop and go traffic.
96 F350 Crew Cab Dually. 7.3L stroke. CXracing intercooler, 3" Down pipe, Tru cool max transmission cooler, EBV delete.
just to live does not mean you're alive
Poh is offline
post #3 of 11 (permalink) Old 07-13-2012, 01:25 AM
strokin6L's Avatar
Damn...my trans will not go past 145* when non towing. First thing i'd do is install a deep trans pan. I have a mag-hytech pan on mine. I've towed a few times and when i did the hotest it ever got was 155*.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #4 of 11 (permalink) Old 07-13-2012, 01:38 AM
Poh
Poh's Avatar
Originally Posted by Poh View Post
120 is too low
16,000 pounds behind my 8000 pound truck......
I get up to 150 going down the hwy @75 - 80 mph.
Poh is offline
post #5 of 11 (permalink) Old 07-13-2012, 02:47 AM
Juniorssrollin's Avatar
Mine will hit 170-180 towing in traffic
Sent from my DROID RAZR using AutoGuide.Com Free App
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
post #6 of 11 (permalink) Old 07-14-2012, 03:19 AM
TheReelMuhcoy's Avatar
Just normal driving on a 80 degree summer day I am at 170Deg. The other day it was 95 and normal driving was 180deg.
I have been thinking about doing the same thing, found some decent looking coolers from Jegs. I would try the deeper pan first though, I would think the extra fluid would help.
-Jon
TheReelMuhcoy is offline
post #7 of 11 (permalink) Old 07-14-2012, 03:36 AM
The cooler would also add extra fluid capacity...and it would definitely do the job
post #8 of 11 (permalink) Old 07-16-2012, 03:28 PM
I have been curious about this as well. I just towed around 7500lbs for 70 miles in 90+ degrees and it would hit 182 or so but stay around 176. Without a trailer on hot day its around 165 to 170
Built by Tri County Diesel
06 F250 CC SB Lariat FX4
ARP Head Studs
AFE Stage 1 Intake
Upgraded FPR (Blue Spring)
6.4 Banjo Fuel Bolts
Sinister EGR Delete
SCT (tuned by Vivian, Looney Wild)
Edge CTS
Sinister Coolant Filter
PowerMax Turbo
Zoo Dad Mod
IDP FICM Tuned
justin99 is offline
post #9 of 11 (permalink) Old 07-16-2012, 06:35 PM
180 isn't that bad. As long as you stay below 200. At 240 the heat starts defacing the clutches.
2004 ford f-250
S&b cai, powermaxx, cfm, arps, mbrp, innovative, 6.4 banjos, blue spring, sinister delete kit, sinister coolant filter, 58v ficm, spearco intercooler, cts.
soon to come s472 and everything to support
04_stroke is offline
post #10 of 11 (permalink) Old 07-17-2012, 02:56 AM
Power Junky
Lubbockguy1979's Avatar
With the fluid too cold you filter never get used. So basically if you plan to add capacity and defeat the factory design you might want to use a 08+ pan filter. the stock setup is thermostatically controlled which bypasses the filter till the unit is up to temp. The stock 6.0 cooler is very effective and plenty large for what ever your towing.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
