scan gauge 2 side port - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-11-2012, 02:08 AM Thread Starter
tatertot
Ok tried to day to run my scangauge plugged into the OBD2 connector and plug my live wire into the side port of the scangauge no power what so ever. So I guess I have to buy a Male OBD2 plug to two female ones to run both at the same time any one else have this problem.
tatertot is offline
post #2 of 6 (permalink) Old 07-11-2012, 02:28 AM
Re: scan gauge 2 side port
u didnt blow the fuse did you? theres an obd2 fuse it blew on me once
what a mess is offline
post #3 of 6 (permalink) Old 07-11-2012, 04:09 PM Thread Starter
tatertot
no scan gauge is still working just when i pliug the sct into the side it doesn't work
2003 F-250 4in turbo back, Blue spring, EGR Delete AFE cold air intake W Blade runner intake, Sinster coolant filter, scan gauge II and sct with egt probe,
MTW HYBRID turbo
Still rolling on stock sticks 202,000 and counting
tatertot is offline
post #4 of 6 (permalink) Old 07-12-2012, 02:58 AM
im pretty sure you cant use both at the same time someone eles will no more
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
Boost got you loose
14.3 with a 2.6 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE :thumb:
2wd-FIRE is offline
post #5 of 6 (permalink) Old 07-20-2012, 02:26 PM
Duck Hunter
Whstln's Avatar
I think you can run both but like you said you just need a splitter at the OBDII port. I don't think you can run it off the side port from the scanguage II it is to be used for tethering between two scanguages. The protocol between your live wire and the scanguage is going to be different.
2000 F-250 6-SPD CC - SOLD
2006 F-250 FX4 Lariat CC
MagnaFlow 4" Dual Exhaust
K&N Cold Air Intake
SCT w/Custom Tunes
PMM EGR Delete
PMM Coolant Filter
Blue Spring Update
3" lift with 295/70/17 Cooper ST MAXX
****Many more to come****
Whstln is offline
post #6 of 6 (permalink) Old 07-20-2012, 03:15 PM
Administrator
Zmann's Avatar
they may have a conflict . I also run a splitter but my CTS will conflict with My A/E but it was worth a try
Amazon has the splitters at a decent price,, I bought Mine from ScanTool
DTR's Donation page
RIP DTR Ron
Zmann is offline
