Airdog or Fass??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 43 (permalink) Old 07-04-2012, 05:17 PM Thread Starter
shmokenpstroke's Avatar
Airdog or Fass???
installed a fuel gauge few days ago..good thing i did..
63psi at idle...drops to 20psi at wot..hfcm is on its way out.
what do fellas reccomend?
i have an 05 6.0, with srl tune, php ficm programmer. blue spring mod, straight pipe exhaust..
i want to do away with the factory pump set up all together..
please give me input..
05 F350 Single Cab.
4 Inch Turbo Straight
MPD 205/100s
Billet 66/73/.91
Driven Disesel Regulated Return
Arps
Volant Intake
Performace Machine Coolant Filter
Moto Metal 962-Wrapped In 305/55/20
Sct-Gearhead
58V Ficm
Fass 125
Isspro EV2-Boost, EGT, Fuel
Edge Insight CTS Only For Gauges
OEM Oil Cooler
RCD Egr Delete
shmokenpstroke is offline
post #2 of 43 (permalink) Old 07-04-2012, 06:58 PM
Agjake11's Avatar
Re: Airdog or Fass???
Aeromotive a1000 or a fuel lab pump.
Search and see the number of issues people have with the ad2
04 F250 - 6.UHOH. Studded and Deleted By PSE, Fueled by Warren and Aeromotive, and Tuned by Gearhead.
08 Tacoma Work truck. V6 Power nothing, Radio, AC, and 4x4
Agjake11 is offline
post #3 of 43 (permalink) Old 07-04-2012, 08:03 PM Thread Starter
I was leaning towards Fass platinum [email protected]
05 F350 Single Cab.
MPD 205/100s
Billet 66/73/.91
Arps
Volant Intake
Sct-Gearhead
58V Ficm
Fass 125
OEM Oil Cooler
RCD Egr Delete
post #4 of 43 (permalink) Old 07-04-2012, 08:04 PM
Administrator
Zmann's Avatar
stock for me
too many problem threads for the Fass motors
also you may have a restriction somewhere that won't be resolved with a new pump
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 43 (permalink) Old 07-04-2012, 09:30 PM
where would you get the pumps you are talking about
what a mess is offline
post #6 of 43 (permalink) Old 07-04-2012, 10:18 PM Thread Starter
I did alot of diagnosis. I blocked off return line and drove it. Still went down to 20psi..its def the pump. Ans Fass cleaned up their act they solved their problems.
05 F350 Single Cab.
MPD 205/100s
Billet 66/73/.91
Arps
Volant Intake
Sct-Gearhead
58V Ficm
Fass 125
OEM Oil Cooler
RCD Egr Delete
post #7 of 43 (permalink) Old 07-04-2012, 11:48 PM
Administrator
Zmann's Avatar
I don't agree with Fass not being a problem anymore ..
based solely on f what I see on the forums ,, so while it is not first hand info I don't see the need for an upgrade over OEM pumps unless your running mods that flow way more fuel?
other than the air separation benefit that some aftermarket pumps offer .. just My 2 cents
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 43 (permalink) Old 07-05-2012, 12:28 AM
'05 Excursion
Term3's Avatar
The early AD2's did have some issues but they have changed the regulator material. If you slap a high volume pump on your truck without upgrading the suction side of it then your going to have issues later on. I have had an AD2 for over five years with zero issues and do a lot of towing in all weather so my AD2 is worked hard. There are a lot of good combinations out there, just do a little research. My setup has the AD2 pulling from a fuel sump through 3/4" SS tubing (yah a little on the large side ), then pushed through 1/2" SS tubing, to a "Y" block then braided SS hose to the front of the heads. It wasn't until about a year ago I built a RR return, but not for the reason most guys put them in for, which is for uniform fuel pressure to the injectors.
Term3 is offline
post #9 of 43 (permalink) Old 07-05-2012, 01:17 AM Thread Starter
well im gonna throw a known good 6.0 stock pump on tomorrow to make sure its 100% my pump thats causing low pressure at wot..and if it is im going to buy a stock pump and just be done with it since im still running stock injectors. when i go bigger ill buy a fass or airdog.
05 F350 Single Cab.
MPD 205/100s
Billet 66/73/.91
Arps
Volant Intake
Sct-Gearhead
58V Ficm
Fass 125
OEM Oil Cooler
RCD Egr Delete
post #10 of 43 (permalink) Old 07-05-2012, 01:23 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
I dont care what people say about ONLY the "early" AD2's have problems. I still hear about people that are getting the AD2s and guess what?? Yep they are still sh!tt!ng the bed. I heard the AD1s and low pressure FASS units were way more reliable and so that is what I went with and so far (~2500 miles) and still good. I also havent heard of anyone running either the A1000 or Fuelab pumps taking a dump so I went with an A1000 so we'll see. I only have about 1k miles so far. JMO take it FWIW. I did A LOT of research on fuel setups and the AD2 is NOT what I could ever recommend to anyone to run on their truck. In fact many reputible shops have stopped selling the AD2 due to the high failure rate.
Nate
windrunner408 is offline
