Question about stacks? (Exhaust) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 07-03-2012, 12:57 PM Thread Starter
dieselnoob.
I understand many of you dont like stacks, oh well.
Im looking to get a single, black, offset from the center, closer to the driver side, angle tipped stack. somewhat big, maybe 6ish inches!
I looked around online, and im confused as heck, I looked on other posts and they really didnt do much to help.
im coming from a stock exhaust system on an 04 f250 6.0 cclb
are there any downsides except noise?
are there brands i need to stay away from? and some i need to look at?
any help would greatly be appreciated guys!
2004 f250 ccsb rwd, rcd egr delete, oil cooler, pmm coolant filter, straight piped
shreyshah1120 is offline
post #2 of 16 (permalink) Old 07-03-2012, 02:16 PM
kingstroke's Avatar
Re: Question about stacks? (Exhaust)
I dont mind because my truck is black but you will get a good amount of soot on the back window and upper cab im running a pypes brand and love it but mbrp is good too
2003 250 ccsb
8"lift 20x12+38 toyos
2007 crate motor,arp studs,bo gaskets, powermax batmowheel, eric tunes and other what nots
kingstroke is offline
post #3 of 16 (permalink) Old 07-03-2012, 02:35 PM
03fathead6.0's Avatar
I have dual 6 inch miter cuts that are 36 inches just enough to barely be seen from the front of the truck, cat delete and muffler delete. The sound is not obnoxious sounds more like a nicely exhausted 5.0 stang when the skinny pedal goes to the floor but lets out just enough turbo whistle around town and cruising. The kit from grand rock was straight forward and simple. only took me about 45 minutes to a hour to put it all on. get yourself a good 5 inch hole saw for the bed super clean cut and be sure to measure everything before the cutting starts, best of luck man.
03fathead6.0 is offline
post #4 of 16 (permalink) Old 07-03-2012, 03:36 PM
powerstrokedkid87's Avatar
im not a fan of the stacks, but we have installed quite a few sets...silverline makes a decent kit, and i like there black stacks, they are almost a black chrome so its a very sharp look
completley stock truck...just a simple cat back system....and maybe a few other odds and ends
powerstrokedkid87 is offline
post #5 of 16 (permalink) Old 07-03-2012, 03:41 PM
to op gonna be kinda tricky to put it offset towards drivers side on stock truck
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
Boost got you loose
14.3 with a 2.6 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE :thumb:
2wd-FIRE is offline
post #6 of 16 (permalink) Old 07-04-2012, 03:25 AM
If you want a sweet setup that looks awesome but comes with a higher price tag check out fte diesel. They make kits that go to 3.5, 4, or 5" exhaust. 3.5" being stock size if I remember correctly. Check out there website.
It may help if ya know the name of what stack ya want. Miter is the angle cut stack 45 degree, turnout, bull hauler, Aussie, cat style, flat cut just to name a few
T-rav
2010 F350 6.4- H&S, AFE stg 2, newton leveling kit, Newton traction bars and a bunch of LED lights
Holderdown Performance #teamHDP
OUR FLEET: 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #7 of 16 (permalink) Old 07-04-2012, 03:42 AM
got another 7.3
smokinford07's Avatar
Send a message via AIM to smokinford07
Honestly, I've never bought a stack kit. I've made any one I've ever done out of old semi stacks. Depending on what kind of black you want, believe it or not I've had great luck lightly scuffing the stack and painting it with cheap matte black rattle can paint.
E99 (Red Truck) 4x4, 7.3 4"DP into 5" Flo-Pro exhaust, DIY tymar, 3/8ths fuel line with a holley blue pump,and a PHP Phoenix (stock, 65t, 80dd, 100 performance, 120race, no start) 140v IDM, 285/75/16 Goodyear Duratracs
E99 (Black Truck) 4x4 7.3, 6 speed with a junked motor right now
smokinford07 is offline
post #8 of 16 (permalink) Old 07-04-2012, 04:44 AM
96powerstroker's Avatar
hell yeah homemade makes it that much more your truck it unique not just a store bought part
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #9 of 16 (permalink) Old 07-04-2012, 08:56 AM
There's no downside if you don't mind losing bed space, hacking a hole in the bed and hurting resale value, exhaust drone, etc.
I'm not a fan of stacks.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #10 of 16 (permalink) Old 07-04-2012, 10:52 AM
tonka350's Avatar
I'm not a fan of them to be honest but the only downsides I saw was when my truck was red, even stock tuned I had exhaust soot all over the truck after rain and not capping the exhaust....here in Virginia you only know it's going to rain about 10 minutes in advance lol, and the exhaust drone, which wasn't horrible to be honest, and after removal the hole is pretty hard to fix, but I've found finding a junk bed in a junkyard and getting a patch panel is the best route to fix that issue. best of luck with your adventure, hope you like it.
Chad
00 F350, 08 clone, 3" cowl hood,billet grilles, 15" lift, 40" SS M16'S, 24X12 Rockstars, 2% tint, EBPV Delete, 4" duals w/7" tips, 6637 intake, WW, CCV Mod, PHP 80,120 race,140 Extreme, stage 1 single shots, 6.0 I/C
Chad
tonka350 is offline
