I asked for it, now not sure i like it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-01-2012, 11:34 PM Thread Starter
slyfly76's Avatar
Ok i decided to install a 4" turbo back exaust and now at certain rpms i get a vibration more accurately a resonance like blowing into a pop bottle and making it hum, yikes it like i'm real aggressive mudders, let off the throttle it goes away hit the throttle and it goes away but 1500 rpm its very annoying any thoughts I've triple checked clearance no issues there. Btw its an 04 f250. Thanks in advance for any tips i'm new to the diesel game and still learning.
slyfly76 is offline
post #2 of 10 (permalink) Old 07-02-2012, 12:11 AM Thread Starter
slyfly76's Avatar
Re: I asked for it, now not sure i like it?
Any thoughts?
slyfly76 is offline
post #3 of 10 (permalink) Old 07-02-2012, 01:34 AM
My other twin turbo...
eleventhtruck's Avatar
Is it all pipe, or do you have a muffler?
eleventhtruck is offline
post #4 of 10 (permalink) Old 07-02-2012, 01:44 AM
check your downpipe turbo clamp they are a pain in the but and alot of times when u think you have them sealed they rnt i ended up dble nutting mine once i got the leak fixed
what a mess is offline
post #5 of 10 (permalink) Old 07-02-2012, 01:51 AM Thread Starter
slyfly76's Avatar
Its a straight pipe no cat or muffler, and i tightened the hell out of that clamp!
slyfly76 is offline
post #6 of 10 (permalink) Old 07-02-2012, 02:07 AM
The Sound Of Madness
dieselboy01's Avatar
I had the same problem and found a u bolt rubbing the heat shield. Maybe double check everything?
L99 SCSB 7.3 4x4 AEM intake, 5" straight pipe, 6pos Gearhead chip, Autometer gauges, Firestone bags, ATD Built tranny, Smoked lights, 15% tint, WW, Mr. Bobs boots & hoses, Leveled, Moto Metals
'02 F-250 RCLB 5.4 XL Plow truck
05 F-250 SCSB 6.0 XLT Plow truck
Remember kids, chrome wont get you home
dieselboy01 is offline
post #7 of 10 (permalink) Old 07-02-2012, 03:24 AM
Check firewall, downpipe, up pipe clearence.
07 f250 rclb. slow and low on 33s.
Originally Posted by BogginF350 View Post
They must of been watching your mother.
white07psd is offline
post #8 of 10 (permalink) Old 07-02-2012, 12:29 PM Thread Starter
slyfly76's Avatar
Ok i found rub marks on exhaust by the spring hanger when the truck is not running there is clearance but when running at certain rpms its obviously touching can i put something between them like heat resistant rubber to deaden the sound? Problem is if i go away from the spring hanger clearance on the up pipe becomes an issue any help on this is appreciated i know someone has had to run into this before i'm thinking about adding a dimple with a hammer but only as a last resort.
slyfly76 is offline
post #9 of 10 (permalink) Old 07-02-2012, 01:57 PM
Good ol boy
04 f350's Avatar
Loosen the turbo clamp until u have enough clearance from all the cross members and everything mine use to do the same thing and it takes a while to get it right, just make sure u get it spaced out enough because when the truck is on its gonna vibrate alot specially from the downpipe , once u get it where u want it with good enough clearance on both sides tighten the [email protected]@t out of the turbo clamp
Studded and Deleted
5 inch axle dump
Back Road Performance Tuned
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #10 of 10 (permalink) Old 07-09-2012, 08:54 PM
douglash's Avatar
I broke a clamp doing that, really pissed me off. Don't tighten it too much your knuckles will thank you.
2004 EB Excursion
douglash is offline
