edge platinum and 05 6.0 HELP! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-01-2012, 04:09 PM Thread Starter
obs stroker's Avatar
so i purchased this clean 05 39K like new had it 5 months just purchased a edge juice pltinum with attitude monitor he says ry it out for a week you like it buy it if you dont no hard feelings so i ry it out works fabulous, so i but it approximently another week goes by i notice in the morning at cold start it will fire right up then it would hesitate real quick and it got worse to where it shut off then fre right back up, and to make a long story short it wont run with it now, but if i keep pissin with it and keep drivin it, it cuts in and out and seems like once you get 10-15 minutes on the road it will run fine then as soon as you shut the truck off and set for 20-25 minutes it will start cutting out again im at a loss idk iv tried everything from turning it all way down to stock setting befor shutting down to inspecting unit and seen where it might have had some moisture but was from the passed and the kid said it worked fine on his, idk what to do it worked like a charm.
FORD STOPPED MAKING TRUCKS ON 7/31/09!
1994 f-250 7.3 turbo diesel, intake, chip, 33's, 5 spd.
1994 f-150 good ol 300 six chipped and intake TB spacer, 5spd.
obs stroker is offline
post #2 of 7 (permalink) Old 07-01-2012, 04:27 PM
06-6.0 stoker's Avatar
I never had that problem when I had that setup on my truck. Cold weather or not. I'm guessing you have another problem with your truck
Sent from my Autoguide iPhone app
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #3 of 7 (permalink) Old 07-01-2012, 04:42 PM Thread Starter
Re: edge platinum and 05 6.0 HELP!
heres the catch i unplug the edge, runs like a new one. idk im lost
post #4 of 7 (permalink) Old 07-01-2012, 04:52 PM
Was the edge brand new? And you made sure you connected everything right? I never had any issues with mine. Try plugging it in and running it on the stock level. Maybe at a higher level it's bringing out a problem
post #5 of 7 (permalink) Old 07-01-2012, 05:34 PM Thread Starter
nope same i did tho one night un hok the batterys and left it over night hooked it back up the next morning started it and it pured like a kittin, tried that yesterday no go, idk i have everything setin out in the sun hiopefully dry it out incase it has moisture
post #6 of 7 (permalink) Old 07-01-2012, 05:37 PM Thread Starter
and pretty sure i hooked it up right blue one went in middle black one went towards cab
post #7 of 7 (permalink) Old 07-01-2012, 08:35 PM Thread Starter
29 views and no ones got anything
