New 205cc injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 06-20-2012, 11:41 PM Thread Starter
New 205cc injectors
Got new 205s on stock 03 turbo reg return 4" dp 4" straight pipe quick tricks looney wild the truck runs like crazy 1200 deg egt wide open 500į @ 70 mph couldnt be happier zero fuel pressure drop from 60psi
blake6.0 is offline
post #2 of 34 (permalink) Old 06-20-2012, 11:56 PM
strokin6L's Avatar
Re: New 205cc injectors
ah...you sure you're looney wild is maxed out for those injectors? Because guys are hitting 1600*+ with just an SCT with custom race tune on stock turbo and stock injectors. I'm willing to bet that your tune isn't maxed out or your EGT gauge isn't reading right.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #3 of 34 (permalink) Old 06-21-2012, 03:14 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Yea I bet you're right Chris. I have 190s and with a turbo that was just slightly larger than stock, I could hit over 1700F with my Xtreme X on a WOT run just from 40-80 mph. It also smoked some SERIOUS coal too.
Nate
windrunner408 is offline
post #4 of 34 (permalink) Old 06-21-2012, 04:03 AM
rdunagan's Avatar
where is your egt probe at?
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me, fusion bumper with rigid led lights
rdunagan is offline
post #5 of 34 (permalink) Old 06-23-2012, 04:29 AM
matt
mgeistman's Avatar
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #6 of 34 (permalink) Old 06-24-2012, 03:33 PM
06-6.0 stoker's Avatar
1700?! That's kinda high isn't it? What turbo you running?
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #7 of 34 (permalink) Old 06-24-2012, 08:53 PM
1700F is high for sure. This was with a VGT turbo that is essentially the same size as a Powermax turbo. I am sure if you talk to guys that have a PM, 190s, and a 0-2000F pyro gauge; they'll all say the same thing.
Nate
post #8 of 34 (permalink) Old 06-25-2012, 04:11 PM
Good ol boy
04 f350's Avatar
1700 degrees is like stupid hot I can't believe it's gettin that hot on you, metal starts turnin red around 1500 so I'm sure your turbo is cherry red after that run
Studded and Deleted
5 inch axle dump
Back Road Performance Tuned
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #9 of 34 (permalink) Old 06-25-2012, 04:48 PM
No not really because I only did it for like a few seconds so the metal never really had a chance to really get the temperature it was at to go up much before I was off the throttle and EGTs were on their way back down.
I can tell you there are A LOT of guys who just run a 0-1600F and "peg" their gauge so they dont know what their temps are getting to. It could very well be hotter than 1700F for all they know. JMO.
Nate
post #10 of 34 (permalink) Old 06-25-2012, 05:15 PM
Good ol boy
04 f350's Avatar
Oh I'm not sayin your lying or anything, I heat treat metal for the company I work for and believe me 1700 is ridiculous hot, I would be scared if I veer saw mine peg that high, but then again I'll prolly nvwr see that with stock injectors and stock turbo
Studded and Deleted
5 inch axle dump
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
