Largest non vgt turbo with ported gogo intake and steed speed exhaust manifold? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 06-15-2012, 11:21 AM Thread Starter
Soon i will be doing my studs, gogo ported intake manifold with egr delete, oil cooler. lots of the ford factory upgrades, and the steed speed exhaust manifolds/up pipe. GoGo advertises their stage 1 manifold to flow an extra 55% of air to the rear cylinders. And Steed speed says on a bone stock truck they picked up an extra 95 hp and 245lb ft of tq on a bolt on set of their manifolds and 2.5 inch up pipes. More air in=More air out... With the heaviest fueling possible out of stock injectors; what does everyone think would be the biggest non vgt turbo i could spool, but still keep when i do decide to do injectors. Not trying to buy two different turbos. Im not worried about lag as i used to drive a 12 valve cummins with an 80mm compressor wheel on it. 64/66 mm turbo possibly?
Opinions?
Go-Go Diesel 6LSTG1 Stage 1 Intake Manifold w/ EGR Delete 6.0L Powerstroke
Steed Speed - Ford 6.0-6.4 powerstroke performance headers
Current: 06 F-250 Fummins, 12 valve, zf6, 370's, full cuts, o ringed, studded, pinned hx55, common rail intercooler, short shifter, lowered on 35's
Hazinhtown is offline
post #2 of 39 (permalink) Old 06-15-2012, 11:26 AM
i like to party
pizza pig's Avatar
Re: Largest non vgt turbo with ported gogo intake and steed speed exhaust manifold?
64mm compressor inducer is going to be a sweet turbo with stock sticks and that setup. make good clean reliable power. A 66 needs more fuel.
pizza pig is offline
post #3 of 39 (permalink) Old 06-15-2012, 12:05 PM Thread Starter
Any idea what hp that would be sitting close to?
post #4 of 39 (permalink) Old 06-15-2012, 12:15 PM
Gettin there
06_WhiteBull's Avatar
I'm a newb and just starting to explore turbo's, but how long before you upgraded your sticks? I wonder if a 66mm with that setup and tuning would clean up 175/75's?
06_WhiteBull is offline
post #5 of 39 (permalink) Old 06-15-2012, 12:20 PM
Gettin there
[QUOTE=Hazinhtown;1856400] And Steed speed says on a bone stock truck they picked up an extra 95 hp and 245lb ft of tq on a bolt on set of their manifolds and 2.5 inch up pipes. More air in=More air out...
Damn, I thought I was done looking at my build parts list. This looks sweet, I wonder if it really stands behind the claim. If so......gotta start workin some OT again.
post #6 of 39 (permalink) Old 06-15-2012, 12:24 PM Thread Starter
FYI... You must buy aftermarket up pipes for these manifolds... Elite diesel has them for an additional 1,000. Yikes. But I'm now one of 25 powerstroke owners with their manifolds. Kind of neat.
post #7 of 39 (permalink) Old 06-15-2012, 01:00 PM
Gettin there
1000 for pipes AND A 1000 for manifolds?
post #8 of 39 (permalink) Old 06-15-2012, 01:10 PM
strokin6L's Avatar
[quote=06_WhiteBull;1856422]
those number were from a 6.4 that was tested....not a 6L. I do remember that Speed would expect the 6L to have at least half those numbers.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #9 of 39 (permalink) Old 06-15-2012, 02:08 PM
Gettin there
AHHHHH.....$2k for @50-65 horse, not worth the OT. Still interested in it though. I'll call them and talk about #'s.
post #10 of 39 (permalink) Old 06-15-2012, 02:12 PM
interested to see how this setup runs subscribed
range91 is offline
