might be a stupid question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-12-2012, 10:34 PM Thread Starter
skinny's Avatar
Sorry guys having a brain fart but got a 03 motor that needs a turbo i got lots of 05-06 ones what do i need to make it work the 05-06 pedistal?
2006 F-350 Amarillo,BD Turbo Thruster II, 5" exh, EGR delete, Sinister Filter, SCT with tunes from IDP, FICM tune from IDP, Edge Cts *dispay*, Blue spring, 6.4 Banjos, 6" lift, 37s with Fuel 20x12 Hoostages, AFE intake, 08 mirrors
skinny is offline
post #2 of 4 (permalink) Old 06-12-2012, 10:46 PM
06-6.0 stoker's Avatar
Re: might be a stupid question
the pedisatal, oil supply and drain lines
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #3 of 4 (permalink) Old 06-12-2012, 10:51 PM
matt
mgeistman's Avatar
hummmmm i thought the only difference was that only one of the bolts wont line up on the turbo mount. only two bolts held mine for a long time till i went non vgt.
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #4 of 4 (permalink) Old 06-12-2012, 11:30 PM
Originally Posted by mgeistman View Post
I thought the only difference was that only one of the bolts wont line up on the turbo mount.
Not if it is an early '03.
While the early '03 does have a slightly different oil supply line, it will work on the later model turbos. Here is a pic showing the difference, which is the connection of the supply line to the oil cooler cover.
This style should be replaced simply because the flexible stainless steel portion of the line can develop a restriction to the oil flow.
Problem with that is, to update this line to the newest style would require the replacement of the oil cooler cover ($$$/time).
The oil drain line will work, but for the relatively low cost of a new line, it should be replaced. It has been updated a few times since '03, and is a much better design (it is now mandrel bent to maintain the inner circumference on the bent portions of the line, to increase oil flow).
'06 F-350 6.0 Excab short box 4X4 Lariat FX4
Bulletproof oil cooler w/cold weather package, blue spring, EGR delete, CCV mod, edge insight and autometer gauges
NYC F-350 is offline
