XDP Fuel Sump Install Review - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-09-2012, 07:09 PM Thread Starter
I Love Work'N On Hot Rods
windrunner408's Avatar
So I have been running my AD150 with my OEM fuel pump for a few weeks now and really like how much more quiet the truck runs and everything. It keeps my fuel pressure at 64psi whether at idle or WOT with my 190/100s and Eric's Xtreme X even; but I kept noticing that I would have a few drops of fuel drip when I parked my truck after driving, which told me that I had fuel leaking some where. So I looked under the truck and of all places, it was coming from the pipe in the filler hose that the air return connects to. I am not sure why it was leaking but it really didn't surprise me because that hose was pretty old when I cut it and I probably should have replaced it when I installed the AD150. Oh well live and learn I guess. So I decided that since I was gonna have to drop the tank to fix this, I figured I might as well install a sump while I was at it. I had thought about a few different sumps (TSD, Beans Low profile, and XDP). I ended up choosing XDP because of free shipping AND 10% off so I got the sump for $148 shipped.
My initial impressions were that everything looked really well built. No rough edges. The black coating all looked good and it came with stainless steel hardware. The instructions were VERY good and had A LOT of pictures, but in all reality they are overkill and this isnt really a complicated install IMO.
I should NOTE here that XDP calls this a "no tank drop" sump; but IMO, you are an idiot to not drop the tank or pull the bed so you can remove the sending unit to gain access to the tank to clean out all of the sh!t that gets in the tank from installing the sump (as you will read about here shortly).
I found the install of this sump to actually kind of be a PITA and more difficult than I thought it should have been. It wasn't that there was some mysterious trick that had to be done but that I had to actually drill out the bolt holes on the sump by 1/64th of an inch to get the 1/4in bolts to even be able to slide though the holes. Also as the instructions recommended 1/4in holes, I found that the extra 64th of an inch really helped out in allowing the bolts to align straight enough to thread into the sump retainer inside the tank. Well as you can imagine, I did A LOT of drilling and the aluminum and plastic shavings get everywhere. Nevertheless, since the tank was out and on my garage floor, it was easy just to wipe everything back up and call it good. The sump comes with a rubber gasket to seal around each bolt but XDP recommends also using some silicone sealant to ensure everything seals up nice. I used some Permatex Formula No. 2 sealant that is resistant to oil, gasoline, and other fuels; and it stays pliable and doesn't harden. So far with about 7 gallons of fuel in the tank, everything seems to be sealed just fine.
Like I said in the beginning, the XDP sump is a very high quality piece (I was able to see all three in person before) but I really didnt like that the bolt holes were so small that I couldnt get the supplied bolts to pass through and even though it says it is a "no tank drop" sump, I would highly recommend dropping the tank and playing it safe. JMO and hope this helps some folks out there looking to install their own sump.
Nate
windrunner408 is offline
post #2 of 7 (permalink) Old 06-09-2012, 09:22 PM
Diesel Freak
StrokeThis34's Avatar
Send a message via AIM to StrokeThis34
Re: XDP Fuel Sump Install Review
What's the benefit?
2005 F-250 KR 6.0 -HDP-
-A little bit here and a little bit there
Big thanks to Holderdown Performance!
Big thanks to Warren Diesel!
StrokeThis34 is offline
post #3 of 7 (permalink) Old 06-09-2012, 10:07 PM Thread Starter
The benefit is that I was able to get rid of my draw straw to the AD150 and when the tank is full the hydrostatic pressure will actually feed the AD150 thus removing the strain of having to lift the fuel out of the tank.
Nate
post #4 of 7 (permalink) Old 06-11-2012, 02:14 PM
6.0stroken's Avatar
Im getting ready to install a sinister no drop sump on my truck. Comes with everything to do the job. Ill be dropping the tank also to play it safe too.
04 f-250 quad cabin 4x4 auto 5r110, 190cc 100%, upgraded oil cooler, upgraded fuel spring regulator, 6.4 banjos, airdogII, gogo's direct clutch solenoid, 5'' exhaust with no cat, sct 3015 with xrace,xstreet,looney wild,srl+,ddp,rcd,super panty dropper, arp headstuds, sinister coolant filtration, sinister egr delete, moderate tuned 58v ficm.
6.0stroken is offline
post #5 of 7 (permalink) Old 06-11-2012, 02:24 PM
powerstrokedkid87's Avatar
agreed....although most kits we deal with are no tank drop kits...for the time it takes to drop the tank or pull the bed...its just worth making sure everything is nice and clean...and its much easier to install the kits....we always drop the tanks
completley stock truck...just a simple cat back system....and maybe a few other odds and ends
powerstrokedkid87 is offline
post #6 of 7 (permalink) Old 06-12-2012, 02:07 PM
6.0stroken's Avatar
I never had to pull my bed. Why would you have to pull the bed?
post #7 of 7 (permalink) Old 06-12-2012, 02:46 PM Thread Starter
You would either pull the bed or drop the tank. Not both. You can also do it with the tank on the truck but I wouldnt. There is just too many shavings and other stuff that need to get wiped out, which is why I drop the tank. JMO though. To each his own.
Nate
