6.0 external wastegate? anyone ever do it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-07-2012, 01:28 PM Thread Starter
i just got all the parts to go to a T4 flange turbo and got a killer deal i couldnt turn up on a 66mm thats not gated. so im trying to figure out the best way to keep drive pressures down and not blow anything up. wondering if anyone could help with the difference between a blow off valve and an external wastegate, pros and cons? and also if anyone has ever done this and has some pics of their setup to help would be great.
rollincoal93 is offline
post #2 of 8 (permalink) Old 06-07-2012, 02:18 PM
strokin6L's Avatar
Re: 6.0 external wastegate? anyone ever do it?
there's a number of guys running an external gate on a 6L and some even have a blow off valve. But the blow off valve isn't gonna help with drive pressure. A blow off valve doesn't do the same thing as a gate. If the turbo is spec'd right...you wont need a wastegate. My 64/71/70 turbo is non gated and boost/drive pressure stays 1:1 all the way to 40psi. After that drive pressure starts rising more than boost. When i dyno'd boost was 45psi and BP was around 53-54psi...that's pretty darn good i think. Just make sure the wheel and housing is spec'd right with the turbo and you shouldn't need a gate.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #3 of 8 (permalink) Old 06-07-2012, 07:29 PM Thread Starter
are you running a blow off valve? do you have alot of bark from it? cause i plan to do quite a bit of pulling and i dont want it to bark too bad if i let out of it.
post #4 of 8 (permalink) Old 06-07-2012, 09:47 PM
i like to party
pizza pig's Avatar
First, what are the specs of the turbo, depending on wheel/housing sizes you may not need a gate.
pizza pig is offline
post #5 of 8 (permalink) Old 06-07-2012, 11:22 PM
strokin6L's Avatar
i have no blow off valve...don't see a need for my setup. Turbo doesn't bark unless i'm on it hard and let off fast. But it also barked when everything was stock when i did the same thing.
post #6 of 8 (permalink) Old 06-07-2012, 11:28 PM
matt
mgeistman's Avatar
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #7 of 8 (permalink) Old 06-08-2012, 03:26 AM
Extended Power's Avatar
If the housing you get with your turbo is an open .88 A/R....you may not need a gate at all.
2003 F-350 KingRanch 4x4
Extended Power is offline
post #8 of 8 (permalink) Old 06-08-2012, 04:11 AM
i like to party
pizza pig's Avatar
nor will is spool very well .
To answer your question between a blow off valve and a externa gate is:
A blow off valve releases surge pressure to the atmosphere, after quickly letting off the throttle. This prevents compressed air from being shoved back into the compressor aka a turbo fart/bark..
A gate wil relieve drive pressure if it raises past a certain pressure ratio, this will prevent overspeedng the turbo or other potentially damaging issues such as blowing up pipes, head gaskets etc.
