Stc bent my branch tube - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-06-2012, 02:46 AM Thread Starter
Question Stc bent my branch tube
So my stroke wasn't starting when hot. I change the standpipes and dummy plugs and it seemed fine until 2 days later it wouldn't start again when hot. Let it cool down and it started right up. I bought an updated stc when I put the egr delete kit on and should of put it on then. Now the stc let go and pushed the branch tube back and put a hair line crack in the back case. Trying to figure out a way to pull the branch tube forward to get the oil pump to bolt back down when stc is attached to the branch tube?? Anyone who has had this or knows any tricks please feed in!! Don't want to pry on the branch tube from back and make the crack any worse. Thanks for any help!!
Lbfd67 is offline
post #2 of 14 (permalink) Old 06-06-2012, 03:38 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: Stc bent my branch tube
Pull the motor and replace branch tube and rear cover
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #3 of 14 (permalink) Old 06-06-2012, 03:50 AM
matt
mgeistman's Avatar
yep
4'' exhaust, egr delete, upgraded oil cooler, arp studs,50mm BOV, volant CAI, 66/73/.91 turbo, 205/100 injectors, crossover fuel line, airdog II, sct by TSD & ID, high idle mod, nitrous express with .092 jet, 26 GPH water/meth, ats stage 3 tranny, king Ranch front and rear captins chairs, and of course kicker sound system
mgeistman is offline
post #4 of 14 (permalink) Old 06-06-2012, 06:30 PM
Ian123's Avatar
ouch
2007 F-250 CCLB Lariat FX4 6.0L
Originally Posted by fuekear View Post
I just blow my heads off the block once a year. Keeps nice clean antifreeze in it, although not that cost effective it sure is fun.
Ian123 is offline
post #5 of 14 (permalink) Old 06-06-2012, 07:15 PM
whistle tits
ghohouston's Avatar
Ain't that a bitch!
ghohouston is offline
post #6 of 14 (permalink) Old 06-07-2012, 01:53 PM
Thats becoming very common to crack the back cover.another reason do do the fitting as preventive.You can do it by dropping the tranny also.
skippy is offline
post #7 of 14 (permalink) Old 06-07-2012, 05:23 PM
Ian123's Avatar
What about just lifting the cab?
Ian123 is offline
post #8 of 14 (permalink) Old 06-07-2012, 05:31 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
He has to separate the motor from the transmission to replace the back cover on the engine. If wants to pull the motor and tranny to do it he can, if he wants to just drop the tranny he can, and even if he lifts the cab he will still have to either drop the tranny or remove it all and separate it outside of the chassis. I guess I am just getting at the point that lifting the cab is really doing anything extra for him other than more work IMO.
Nate
windrunner408 is offline
post #9 of 14 (permalink) Old 06-07-2012, 08:50 PM
Ian123's Avatar
That sucks. What if he left the cover cracked would there just be a small oil leak or would there be bigger problems? Sorry if this is a hijack just thinking what I'd do if this ever happened to me
Ian123 is offline
post #10 of 14 (permalink) Old 06-07-2012, 09:21 PM
Administrator
Zmann's Avatar
What a PITA
DTR's Donation page
RIP DTR Ron
Zmann is offline
